82' 300 I6
Old Sep 24, 2012 | 07:03 PM
enriched&beyound's Avatar
enriched&beyound
82' 300 I6
Any recommendations for clutch & pressure plate assemblies?? (On a 82' 300 I6, f150, 2wheel drive)
maybe a better question is, what should we stay away from??
this is going behind a fresh OH .03 over on the bores with mild cam.
currently the thought is to keep the factory 4sp ....but open to 5spd suggestions
thanks
Old Sep 25, 2012 | 10:49 AM
1986F150six's Avatar
1986F150six
Most of our trucks have flywheels already drilled for the 11" clutch as opposed to the normally stock 10" unit. The clutch kits [clutch, pressure plate and throw out bearing] cost about $25 more and you have to use different mounting bolts, but in my opinion, you get a much more durable unit.
The 11" was used in the larger trucks equipped with 4.9L engines.
Old Sep 25, 2012 | 06:23 PM
enriched&beyound
thanks....durable is what we are going for.
where can we find the larger and more durable clutch packages??
Old Sep 25, 2012 | 08:52 PM
Gary Lewis's Avatar
Gary Lewis
Any of the parts stores have them. Sachs and Luk are two of the top manufacturers. I got my Sachs package from O'Reilly's. Paid $109 for a clutch, pressure plate, throwout bearing, and pilot bearing. Could have gotten just the clutch itself for $108. Didn't take me long to figure it out.
Old Sep 25, 2012 | 09:35 PM
Yaga1973's Avatar
Yaga1973
Elder User - What???
Ah, some answers to a question I was eventually going to ask for Frankentruck. Thank you to both of you!
Has anybody had any luck with Centerforce clutches and throwout bearings? I wasn't sure if the extra price for them would be worth it or not.
Old Sep 26, 2012 | 06:08 AM
enriched&beyound
thanks again!
I personally have not heard of either of those two brands ( Sachs and Luk), but then again, I do not do clutch or tranny work, this is a home project.
In our neck of the woods O"Reillys tends not to carry the better brands...& we are not too keen on the prospect of going in there & do it again again theme.
Yaga1973
Centerforce clutches and throwout bearings? I wasn't sure if the extra price for them would be worth it or not?
^ as for Yaga1973...these I have heard of....& Have the same thought...but like all things, some companies items are best suited in different applications...not that they have "bad product" or anything ...just not that particular companies best suited application.
so what about Hayes or Zoom clutch packages?? any feed back on those?
Old Sep 26, 2012 | 06:27 AM
garthneddy's Avatar
garthneddy
I also have a clutch kit from O'Reileys and it has been good to me. The only other brand i have run was a ZOOM clutch for my 390. That thing was alot grabbier then the one I currently have in my F250.
Old Sep 26, 2012 | 08:09 AM
Gary Lewis's Avatar
Gary Lewis
Some say bad things about the various parts stores, but it really boils down to the people who work there. All of the stores can get good parts, and most of them carry a line of cheap parts. Most, if not all, of the employees in the local O'Reilly's know their stuff, and some have been around the parts business for decades. They have steered me right many times when I've asked for their input, and I appreciate it.
But, if the employees don't know the business and don't have decades of background then the computer systems they are using can cause problems as it doesn't provide info on other parts that might/will fit. So, we, the buyers, have to do a lot of research. And that's where O'Reillys has really shone - they ordered in several clutch kits for me to measure and took them all back with nary a word. I finally found the one I was looking for and bought it from them.
Centerforce, IIRC, came up through the hot rod ranks, meaning it is set up for high performance, and has been very well thought of - but expensive. Zoom was/is similar but not as expensive. But, one problem with high performance is the tend to be able to handle a lot of power and can be grabby in day-to-day driving.
Old Sep 27, 2012 | 06:01 AM
enriched&beyound
Agreed...key to any parts store...is the quality of the folks behind the counter, no doubt! It is great that you have those where you are.
I appreciate the good feed back and we'll assess the end use of this Ole truck and I'm sure we'll get a good fit to our need, now that we have better insight. thanks again
Oh...1 more thought/question.....Are the clutches (or transmission for that matter), different, if, this gets turned into a 4x4??? this is another possibility
candoo
Jul 21, 2015 09:23 AM
MER
Apr 10, 2008 11:11 AM
kevan b
Jul 20, 2004 08:41 PM
bamagrasshopper4
Jul 25, 2002 04:49 PM
exploringnva
Jul 25, 2002 06:55 AM
