- 79-80 crossover
- "Classic" 1986 F250
- 2 different problems... 4x4/ coolant
- Hurst Floor Shifter
- Can someone tell me how to fix a fan speed switch?
- thoughts on using RTV with a gasket
- 1982 F100 3 speed manual transmission identification
- Hate to do this, vin decode
- Clutch question...
- 87-96 2wd kit work on 80-86?
- Heads
- Parts interchangeability
- issues starting and rough idle
- Do you know the size of...???
- Hydraulic Flat Tappet Cam Break In Procedure
- Simple vacuum question, for anybody with a 300 six
- 1986 351 W 4wd-oil pump
- Oil Circulation Problems
- Broken Transfer Case Sleeve.
- How to clean fuel injectors?
- 1980 to 1985/6 frame swap, a few questions
- 1981 Rim Change HELP!
- I think I have a Dana 70 and not 60, questions about rear brakes
- Help with vacuum lines
- throttle body?
- not a typical lift kit question
- 1982 F-100 stepside engine swap questions
- Sound system
- Brake Problems - '85 F-250HD
- 1986 f150 not running right
