2 different problems... 4x4/ coolant
Old Oct 24, 2013 | 12:29 PM
Natcox012's Avatar
Natcox012
Alright bought a 1988 f250 4x4 last week already had a new tank and fuel pump put in it.. Alright when I put it in 4H I want to lung forward and bounce up and down like it's trying to go faster but won't... 4L I don't think does it because it's such a low gear...
Now for my second problem coolant is coming from the top of the water pump a lil inch and half hose going from the intake to the water pump.. It's a 460 efi.. And does fine setting there idling but hit the gas and starts to over heat..
Old Oct 24, 2013 | 06:25 PM
Franklin2's Avatar
Franklin2
Are your tires the same size front and rear? And replace the hose if it's leaking.
Old Oct 24, 2013 | 07:01 PM
joshofalltrades's Avatar
joshofalltrades
Your 4x4 issue is most likely either different tire sizes on the front vs the rear, or different gear ratios in the front axle vs the rear. Read the tags on both axles and post the results if you can't understand them by yourself. Note that you'll likely need to clean the tags with a scraper or wire brush to be able to read the info stamped into them.
For your cooling issue, replace the failing hose immediately and that should solve the problem
Old Oct 25, 2013 | 07:36 AM
Natcox012's Avatar
Natcox012
Yea my tires are the same size just they are a lil bald in the back from the last owner but all the same size.. And going to oriellyautoparts now to get the hose and a thermostat just to make sure... What would getting a cooler thermo hurt anything I know my grandpas used a cooler thermo to just operate on normal conditions...
Old Oct 25, 2013 | 07:40 AM
Natcox012's Avatar
Natcox012
And I can squeeze the top radiator hose and it flows back in the over flow tank... Not suppose to be able to do that right
Old Oct 25, 2013 | 07:50 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Get a new radiator cap while you are at the store.
Old Oct 25, 2013 | 07:52 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You know you're not supposed to use 4wd on dry solid surfaces, right?
Read the warnings on the top of the drivers sun visor.
Making a turn in 4wd on dry pavement will always bind up the driveline and can lead to shaft or transfer case failure.
Old Oct 25, 2013 | 07:58 AM
Natcox012's Avatar
Natcox012
Yea I turned it on, while on gravel to check out see if it will work just got the truck a week ago... :/.. And I was planning and getting a tempature cap but don't know what psi I should get 7psi,20,24..
Old Oct 25, 2013 | 08:11 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
13 psi.
4wd on gravel is fine.
I'm wondering if you have a torn transmission mount or something.
Old Oct 25, 2013 | 08:16 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Get a 195* thermostat.
Your fuel injection will always be compensating for running too cold otherwise.
Carb's aren't 'smart' enough to know better.
Old Oct 25, 2013 | 08:31 AM
Natcox012's Avatar
Natcox012
Alright thanks I'll let yano after I do all the following..
New thermostat and hoses,oil change, belt change, and trans flush then I'll let yano
Old Oct 25, 2013 | 11:48 AM
Natcox012's Avatar
Natcox012
Yup just screwed it up more lol... Went to the the housing off the thermostat and broke the bolt off now have a half in. Nub and it won't come out..
Old Oct 25, 2013 | 01:13 PM
Natcox012's Avatar
Natcox012
False alarm got it
Old Oct 25, 2013 | 01:17 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Usually when it's sticking out like that I just cut a screwdriver slot with a die grinder.
If it is rusted in, that's a different story...
Old Oct 25, 2013 | 06:02 PM
Natcox012's Avatar
Natcox012
Got it it's all good hose Nd thermostat did the trick thanks guys
1974 f100
Jun 10, 2019 03:41 PM
Natcox012
Oct 25, 2013 09:06 AM
Bread
Mar 7, 2012 10:11 AM
97squarebody
Dec 6, 2007 02:47 PM
wickymustang
Sep 14, 2005 03:33 PM
