Sound system
Old Oct 19, 2013 | 10:18 PM
mythbustingpyro's Avatar
mythbustingpyro
Sound system
I am having some issues getting my new radio working. The previous owner mucked up the wiring and the bezel already so I'm not too worried about changes to either of those (though I might be interested in a new bezel eventually).
It had no radio when I bought it and my parents purchased me a unit for my birthday. I think I'm having trouble with too high an impedance to pull any real amps again, so instead of pulling through accessory I might pull through a toggle since the radio has an in-line barrel fuse anyway. Anyone see a problem with this? Just gonna run a new ground wire and 12v unswitched for the memory as well.
Also anyone have any speaker suggestions for two additional rear speakers (behind the seat maybe)? I don't have much to spend but don't need super high volume either. May get a lowprofile sub for under the seat but don't have the money right now. As far as the current setup it has two 6.5" two ways from lighting audio.
I've been thinking about adding these:
Amazon.com: Car SUV Truck Wedge Black 6-Inch X 9-Inch Speaker Boxes Sealed 6x9 Enclosures TR69: Car Electronics Amazon.com: Car SUV Truck Wedge Black 6-Inch X 9-Inch Speaker Boxes Sealed 6x9 Enclosures TR69: Car Electronics
Amazon.com: Dual TS69 6-Inch x 9-Inch 150 Watt 3-Way Illuminite Speakers: Car Electronics Amazon.com: Dual TS69 6-Inch x 9-Inch 150 Watt 3-Way Illuminite Speakers: Car Electronics
Amazon.com: Boss Audio BASS800 8-Inch Amplified Subwoofer with Passive Radiator - Single (Black): Car Electronics Amazon.com: Boss Audio BASS800 8-Inch Amplified Subwoofer with Passive Radiator - Single (Black): Car Electronics
This is my unit:
Amazon.com: Power Acoustik PTID-8920B In-Dash DVD AM/FM Receiver with 7-Inch Flip-Out Touchscreen Monitor and USB/SD Input: Car Electronics Amazon.com: Power Acoustik PTID-8920B In-Dash DVD AM/FM Receiver with 7-Inch Flip-Out Touchscreen Monitor and USB/SD Input: Car Electronics
Also just in case my truck is an 82 F100 flareside, and I have 9 inches of space from cab wall to the back of my seat on the bottom (I'm 6'2") I'm obviously not going for a killer system but want something that works pretty good and doesn't break the bank. I'm open for suggestions. Thanks in advance.
Old Oct 20, 2013 | 07:39 AM
Franklin2's Avatar
Franklin2
You should not have to run another power wire, the factory wire has plenty of capacity for that radio. You can go ahead and do it if you like, but I would think it's going to get aggravating having to turn the switch off all the time, and if you turn the radio down all the way for some reason and forget it's on, then forget to turn the switch off, well then you know what happens next.
That powered 8 inch woofer is going to be the best performer of the selection you have. Those 6x9 enclosures don't sound that great if bass is what you are looking for. The speakers you have now will provide all the highs you need already.
Old Oct 20, 2013 | 04:34 PM
mythbustingpyro
The problem is that at some point there was water leaking or just over time the corrosion in the fuse block has gotten so bad that in many places there is so high an impedance in the system that the system can't pass any amps. It happened with my horn in another thread, but scraping off the fuse didn't work this time.
I'm not looking for super heavy bass, never really cared that much for that. I just want a good mid and high range with a decent amount of bass.
I still haven't heard the ones I have but one of the cones (driver side) looked cracked, so I may have to replace that. Are there any better enclosures to use that will fit in my space behind the seat? Or somewhere else out of the way to mount something?
Old Oct 20, 2013 | 04:35 PM
Gary Lewis's Avatar
Gary Lewis
I've read some poor reviews of that subwoofer. But I've read much better reviews of the Sound Ordnance B-8PTD, which is the one I'm planning to get.
Here are some links I've been reading:
Sound Ordnance B-8PTD 125-watt compact powered subwoofer at Crutchfield.com
Sound Ordnance B-8PT Install/Review w/ Pics - Subaru Impreza WRX STI Forums: IWSTI.com
Old Oct 21, 2013 | 01:20 AM
tempest411's Avatar
tempest411
If sound quality is what you're after, then I'd highly recommend sticking with brand names that are more familiar in that arena. Most of the car stuff out there is garbage. Boston Acoustic speakers makes a fantastic speaker! Honestly, just one pair of 6.5 door speakers will rival the other brands being mentioned. I also would've recommended an Alpine or Sony head unit in the same price range. They produce better signal to noise characteristics, the most instrumental statistic in defining how well any audio source will sound. And some day when the budget allows, a JL Audio amp is a pretty nice addition.
Old Oct 21, 2013 | 07:45 AM
Gary Lewis's Avatar
Gary Lewis
I agree on the BA speakers. I installed a complete system from them many years ago in a Miata and was amazed at how well they sounded. The 6.5's would actually move my pants cuff on low notes, and the bass was amazing. So much so that the owner of the high-end audio store in Houston where I bought them called everyone out to listen to it. Apparently the volume of the door, which I had sealed pretty tightly, was just right to work with those speakers.
Old Oct 21, 2013 | 07:58 PM
mythbustingpyro
Got the headunit in tonight and working it was just the 12v constant line that was not working properly. Went ahead and ran a 12v and ground both.
But the passanger side speaker is blown. So Ill be getting a pair of 6.5s. Any models that work really well in these trucks.
Edit: forgot to say that Id prefer sub $50 options
Old Oct 22, 2013 | 12:04 AM
tempest411's Avatar
tempest411
I'd check Craiglist or E-Bay for good used speakers. Better to have better quality second hand speakers than new cheapies.
Like these: http://www.ebay.com/itm/HARMAN-Infinity-REFERENCE-SERIES-6-inch-Auto-Speaker-652I-set-of-2-/390645740989?pt=Car_Speakers&hash=item5af44cf5bd
I've used Infinity before, and they're pretty decent.
Old Oct 22, 2013 | 07:46 AM
Gary Lewis's Avatar
Gary Lewis
I believe those speakers have directional tweeters, meaning they can be aimed at the listener. Makes a huge difference when you have speakers mounted to the sides as the high frequencies "beam" as opposed to the lows, which disperse.
ruschejj
6.7L Power Stroke Diesel
Oct 16, 2014 06:17 PM
lbcarguy
Jan 20, 2013 08:05 PM
mark914
17
Feb 28, 2007 07:09 PM
wanabe2
Oct 23, 2006 03:14 PM
maticuno
Jul 19, 2004 02:55 PM
