Hate to do this, vin decode
Old Oct 23, 2013 | 06:45 PM
dylansf23's Avatar
dylansf23
I'm out and about and ran across this f250 for sale.
Can't find the decoder on my phone, it's on my homepage of my laptop:/
Old Oct 23, 2013 | 08:11 PM
ctubutis's Avatar
ctubutis
The online thing I sometimes use is from Ford Fleet:
https://www.fleet.ford.com/maintenance/vin-decoder/
Old Oct 23, 2013 | 08:25 PM
dylansf23's Avatar
dylansf23
Never gotten that to work.. Always just goes and says the form didn't work right go back and try again
Old Oct 23, 2013 | 08:34 PM
ctubutis's Avatar
ctubutis
It worked for me, even though your picture is sideways and hard to read.
Old Oct 23, 2013 | 08:35 PM
ctubutis's Avatar
ctubutis
Print | Share
VIN Results
New Search <table id="vin-results-table"> <tbody><tr class="vin-number"> <td colspan="2">VIN: 1FTHF2618GNB25628</td> </tr> <tr class="description"> <td colspan="2">World Manufacturer Identifier - 1st, 2nd, 3rd Positions</td> </tr> <tr><td class="label">VIN Code:</td><td>1FT</td></tr> <tr><td class="label">Assembly Country:</td><td>United States</td></tr> <tr><td class="label">Make:</td><td>Ford</td></tr> <tr><td class="label">Body Style:</td><td>Pickup</td></tr> <tr class="description"> <td colspan="2">Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position</td> </tr> <tr><td class="label">VIN Code:</td><td>H</td></tr> <tr><td class="label">Brake System:</td><td>Standard</td></tr> <tr><td class="label">Restraint:</td><td>Active (Manual) Belts</td></tr> <tr><td class="label">GVWR Range:</td><td>6,001 - 10,000 Pounds</td></tr> <tr class="description"> <td colspan="2">Line,Series Body Type - 5th, 6th, 7th Positions</td> </tr> <tr><td class="label">VIN Code:</td><td>F26</td></tr> <tr><td class="label">Vehicle Line:</td><td>F-250</td></tr> <tr><td class="label">Vehicle Type:</td><td>Truck</td></tr> <tr class="description"> <td colspan="2">Engine Type - 8th Position</td> </tr> <tr><td class="label">VIN Code:</td><td>1</td></tr> <tr><td class="label">Engine:</td><td>6.9 L</td></tr> <tr><td class="label">Cylinders:</td><td>8</td></tr> <tr><td class="label">Fuel:</td><td>Diesel</td></tr> <tr><td class="label">Engine Manufacturer:</td><td>INTERNATIONAL</td></tr> <tr class="description"> <td colspan="2">Model Year - 10th Position</td> </tr> <tr><td class="label">VIN Code:</td><td>G</td></tr> <tr><td class="label">Model Year:</td><td>1986</td></tr> <tr class="description"> <td colspan="2">Assembly Plant - 11th Position</td> </tr> <tr><td class="label">VIN Code:</td><td>N</td></tr> <tr><td class="label">Assembly Plant:</td><td>NORFOLK, VIRGINIA</td></tr> <tr class="description"> <td colspan="2">Production Sequence Number - 12th - 17th</td> </tr> <tr><td class="label">VIN Code:</td><td>B25628</td></tr> <tr><td class="label">Prod Sequence Number</td><td>B25628</td></tr> <tr class="description"> <td colspan="2">Additional Information</td> </tr> <tr><td class="label">Wheel Axles Wheelbase:</td><td>266.0</td></tr> </tbody></table>
New Search
Old Oct 23, 2013 | 08:52 PM
dylansf23's Avatar
dylansf23
And a c9 axle is a sterling 3.55 if I'm not mistaken right?0
Old Oct 23, 2013 | 08:55 PM
ctubutis's Avatar
ctubutis
Seems right, but, with Limited Slip:
Source: FoMoCo 1980/1989 Light Truck Parts Catalog (available on CD from hipoparts.com)
Old Oct 23, 2013 | 09:09 PM
dylansf23's Avatar
dylansf23
Sweet this trucks worth getting for a decent price
Old Oct 24, 2013 | 09:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by ctubutis
<table id="vin-results-table"> <tbody><tr class="vin-number"> <td colspan="2">VIN: 1FTHF2618GNB25628</td> </tr> <tr class="description"> <td colspan="2">World Manufacturer Identifier - 1st, 2nd, 3rd Positions</td> </tr> <tr><td class="label">VIN Code:</td><td>1FT</td></tr> <tr><td class="label">Assembly Country:</td><td>United States</td></tr> <tr><td class="label">Make:</td><td>Ford</td></tr> <tr><td class="label">Body Style:</td><td>Pickup </td></tr> <tr class="description"> <td colspan="2">Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position </td> </tr> <tr><td class="label">VIN Code:</td><td>H</td></tr> <tr><td class="label">Brake System:</td><td>Standard </td></tr> <tr><td class="label">Restraint:</td><td>Active (Manual) Belts </td></tr> <tr><td class="label">GVWR Range:</td><td>6,001 - 10,000 Pounds </td></tr> <tr class="description"> <td colspan="2">Line,Series Body Type - 5th, 6th, 7th Positions</td> </tr> <tr><td class="label">VIN Code:</td><td>F26</td></tr> <tr><td class="label">Vehicle Line:</td><td>F-250 </td></tr> <tr><td class="label">Vehicle Type:</td><td>Truck </td></tr> <tr class="description"> <td colspan="2">Engine Type - 8th Position</td> </tr> <tr><td class="label">VIN Code:</td><td>1</td></tr> <tr><td class="label">Engine:</td><td>6.9 L</td></tr> <tr><td class="label">Cylinders:</td><td>8</td></tr> <tr><td class="label">Fuel:</td><td>Diesel</td></tr> <tr><td class="label">Engine Manufacturer:
</td></tr> <tr class="description"> <td colspan="2"></td> </tr> <tr><td class="label"></td><td></td></tr> </tbody></table>Where did you get this confusing and misleading decode info from? It's not from the 1980/89 Ford Light Truck Parts Catalog, that's for darn sure.
1FT = Ford Motor Company USA - Ford Truck (Complete Vehicle).
H = GVWR Class G - Hydraulic Brakes - 8,501-9,000 lbs. Gross Vehicle Weight Rating.
F26 = F250 4WD Pickup.
1 = 6.9L (420 cid) V8 IH Diesel
8 = Check Digit, FoMoCo use only.
G = 1986.
N = Norfolk VA Assembly Plant.
B25628 = 1986 Numerical Sequence of Assembly, the trucks specific serial number.
Old Oct 24, 2013 | 07:15 PM
ctubutis's Avatar
ctubutis
Right, I didn't have the 30-60 minutes it requires to do the manual method, so I sent him to Ford Fleet's very own VIN decoder, which he claims he couldn't get to work so I copied & pasted the results for him.
Old Oct 24, 2013 | 07:40 PM
NumberDummy
Right, I didn't have the 30-60 minutes it requires to do the manual method.
What in the world...30-60 minutes? Is something amiss with your peepers?
It took me less than 5 minutes, and if it wasn't for the fact that I'm a two finger typist, coulda done it in less than 2 minutes.
> I know you have the '80/89 light truck parts catalog. Pages 18 thru 22 in the General Info Section decode the entire 17 digit VIN <
Old Oct 24, 2013 | 08:04 PM
ctubutis's Avatar
ctubutis
I for some reason knew you were gonna say something like this....
I first locate & copy an old post and use it as a template., and I then do everything on the label (not just the VIN)... colors, springs, axles, DSO, etc. etc. etc.
I didn't have the time and this one was sideways, adding even more time to straighten it out so it's readable. So, the online thing had to suffice....
Old Oct 24, 2013 | 08:56 PM
Gary Lewis's Avatar
Gary Lewis
And this explains why some are reluctant to say boo.
Old Oct 24, 2013 | 09:07 PM
ctubutis's Avatar
ctubutis
Not sure what you're getting at, Gary, I do what I can to help, but don't always have time....
Old Oct 24, 2013 | 09:10 PM
Gary Lewis's Avatar
Gary Lewis
I think you misunderstood. I tried to rep you but ...... you know the excuse.
