- Bad PCV valve?
- 460 EFI failed smog
- 460 50K Miles No Smoke and 1QT/100 Miles
- The return of problem child 88F-150 351
- new member with performance ?'s
- difference in a 97 vs 96 & prior
- What's the smaller hole on the gas tank?
- Problem with tires rubbing
- vacuum line
- cleaning a gas tank
- Why is Battery Dying with truck off - ?
- Fan clutch
- Where can I get clear lens turn signals
- Question on EGR Simulator
- Mounting locations for Autometer Tachometer
- auto locking hub to manul hubs ?
- Finally got the *%#@ fuel filter off-'93 F150
- Tach swap - Now ABS light is on....
- Blinkers won't work on '89 F250
- Were there any Maf equiped truck w/MAF?
- radio problem
- 93 f150- rough idle and start bucking with slow acceleration
- 1992 F150 4x4 5.0 fuel problem??
- no thermostat
- Just installed an MSD 6 "Off Road" on 94 F250
- Switch for fuel tanks.
- Iok I'm an idiot
- Grant steering wheel on a 94?
- found one problem with the EGR thing but code still continues,
- Indexing Transfer case
