Question on EGR Simulator
Old May 10, 2007 | 12:59 AM
Jrock909's Avatar
Jrock909
Guys I was wondering if there a EGR simulator out there that will keep the check engine light from coming on and stay off lol!?! I ask this because I just swapped a 302HO engine in and have the EGR blocked off with a custom billet plate? I saw that on fordfuelinjection.com that Ryan had a few simulators and I have used one of them, but it didn't keep the light from coming on...
Old May 10, 2007 | 01:04 AM
taisa899's Avatar
taisa899
you sure it's the EGR throwing the code? And second have somebody with a code scanner clear the codes from your ECU. Sometimes codes are stored in the memory so even if you do the battery disconnect to erase the codes it doesn't get the stored ones
Jim
Old May 10, 2007 | 01:22 AM
Jrock909's Avatar
Jrock909
I have done it all Taisa, I got a scanner and I have cleared the 334 code and it keeps coming back... All I want to do is to keep that code from coming back, but it keeps coming back after I clear the codes... I have cleared the code using a Actron scanner and the battery disconnect method ;-(
Old May 10, 2007 | 07:01 AM
oldproudvet's Avatar
oldproudvet
I blocked my egr w/a plate and left the egr valve connected and in place. The egr position sensor simply measures movement of the vacuum diaphragm
Old May 10, 2007 | 07:23 AM
albung's Avatar
albung
simulator does keep lite off if u had the gray valve on top of egr
