pushrod length double take.
Old Jan 13, 2012 | 07:31 PM
flipklos's Avatar
flipklos
So on murmmets site it lists that 54-56 heads use the short 7.98" pushrod and 57 up use the 8.11 length rod.
In the Y block book it lists 56 up heads use the 8.11 rod.
I am using one ED-ECZ-C head and one 5752-113 head. The Ed-ECZ-C head is a 56.
What is the correct length of push rod. On dissasembly both sides had bent push rods so there is no way of knowing for sure.
Any ideas?
Old Jan 14, 2012 | 09:02 AM
46yblock's Avatar
46yblock
Different pushrod lengths on each side wont be any problem, if that is what ends up being required. Frankly, the different lengths have always been somewhat confusing to me, one of those things that just doesnt stick in the memory bank.
Old Jan 14, 2012 | 09:49 AM
flipklos's Avatar
flipklos
Different lengths should be no issue. But which one to use may be.
Old Jan 14, 2012 | 12:24 PM
charliemccraney's Avatar
charliemccraney
He has pushrods listed in two places. In one 3 separate pushrods are listed '54-'55, '56-'59, and '60-'64. In the other 2 are listed, '54-'55 and '60-'64, and '56-'59. So I'd guess you need the same pushrods.
The difference is about 1/64" which isn't much but the longest pushrod you can fit will provide the greatest rocker ratio. You could take it a step farther and shim them for the best geometry and order custom pushrods.
Old Jan 14, 2012 | 07:23 PM
flipklos's Avatar
flipklos
I have enough stock 1964 length rods on hand and then some. If you set your lash correctly it should cause no issue other than the ratio and angle being off slightly.
john jamieson
Oct 2, 2021 12:38 PM
Myfreeford
Feb 6, 2011 10:42 PM
steve_speak
Sep 29, 2008 08:38 PM
jdstudski
Aug 9, 2008 05:21 PM
76 F250 4X4
Nov 26, 2004 10:23 PM
