PDA
View Full Version : Modular V8 (4.6L, 5.4L)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 [124] 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234
  1. 5.4L oil drain plug
  2. Right bank dead
  3. 2000 F350 5.4 no start problem
  4. 5.4l oil issue
  5. 2000 F250 5.4l Cylinder heads
  6. BBK Throttle Body F-350 5.4 Need # Or A Pic
  7. Misfire?
  8. warm, no start condition in cold weather.
  9. Cleaning throttle body on '05 5.4
  10. Differences in Throttle bodies????
  11. Shift kit needed or not?
  12. fresh rebuilt winsor 4.6 knock
  13. Lightweight Aluminum Idler Pulley ?????
  14. 4.6L Engine Knock
  15. Vibration when accelerating... idles and revs in neutral fine
  16. best power per dollar for 2v 5.4
  17. Aftermarket coil on plugs, anyone have them?
  18. Larger alternator options?
  19. Piston Slap or what!?!?
  20. 4.6 romeo timing chain alignment
  21. Scan Tool
  22. p0401
  23. Engine missing (5.4)
  24. oil leaking from head
  25. po174
  26. ZF6-650 swap for T18/NP435 in F350
  27. Does the 3-valve 4.6 have the stuck plug problem?
  28. 06 5.4L Running rich/lean
  29. blown 4.6l motor?
  30. advancing timing in 5.4L 3v 07 expedition
