- Truck wont start
- 5.4 E350 misfire still "Need Desperate help"
- 2000 Lightning Motor
- Mystery Water Leak on 4.6 F-150
- '97 4.6 spark plug question...
- What upgrades did Ford make to the 5.4L Engine in 1999?
- Idles good in park,bad in drive
- spark plugs
- best coil pack?
- I've about had it with this truck!
- k&n fipk2 v 10 to fit 5.4? anyone try or know
- Engine shuddering under acceleration; code P0171, P0174
- "cam lobe is scratched you need a new engine"
- Ingition coil test
- Hydraulic Clutch
- 5.4 3v air filter foam seal
- Spark Plug Ejected from LH Cylinder Bank
- Two Cylinders getting NO SPARK.
- Code 171,174, now 1131 and 1151
- question on PI heads
- Rebuilding my 5.4L, need help on performance parts
- 91octane with superchips 87 setting
- 5.4 power options???
- black smoke at start up?
- O2 sensor-Right bank-Left bank?
- Gas mileage way down
- 1997 E 350 5.4 Misfire trouble
- one for the experts....
- 1/2 Ton or 3/4 ton....
- Going from 4X4 to 2x4........
