PDA
View Full Version : Modular V8 (4.6L, 5.4L)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 [167] 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234
  1. Hunting misfire, need a little AutoTap help.
  2. Any improvments to the 4.6 from 97 to 2004?
  3. cold starting
  4. 5.4L exhaust leak, lean/rich fuel mixture
  5. 5.4 3v and/or2v??
  6. weak coil pack
  7. engine vibration
  8. Question about plug blowout...I know, I know
  9. which 4.6L in my 2001 Exp
  10. Question on cleaning MAF
  11. 2003 F150 5.4 - Excessive Oil Consumption
  12. vegas trip
  13. Milelage on 3V 5.4 in F250/350??
  14. 4.6 more HP
  15. 4.6 motor problems
  16. Exhaust smells real rich
  17. 5.4 with p0171-174 code
  18. Whats the diff. Mustang vs F150
  19. sensor search
  20. Will only run with air cleaner disconnected from the throttle body.
  21. 4.6 Knocking, not piston slap. Help!
  22. Warm engine ,long cranking time to restart ?
  23. super 5.4
  24. Stock2Racing build
  25. 5.4 with P0401
  26. Replace timing chain as preventative maintenance?
  27. Erratic guages
  28. White Smoke!!!
  29. New type PCV valve ?
  30. P0174: System Too Lean (BAnk 2)
