PDA
View Full Version : Modular V8 (4.6L, 5.4L)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 [164] 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234
  1. Pinging
  2. anyone had their rusty manifold studs replaced?
  3. ignition coil f
  4. po356 ignition coil f prim. second. circuit malfunction
  5. coolant system flush
  6. Base Idle setting on 4.6L
  7. 4.6 / antifreeze
  8. Good value?
  9. antifreeze/sparkplug hole
  10. High idle on 4.6
  11. How big is the problem?
  12. 5.4L Possible Service
  13. another missfire ?
  14. 5.4 L misfire at operating temp.
  15. 5.4 Cams
  16. #3 coil pack
  17. looking for an extra honing torque plate for 4.6
  18. Better heads
  19. firing order
  20. Low Fuel Pressure = Miss ?
  21. 5.4L Shudders under load/rough idle
  22. Coolant in Oil Sump, any ideas?
  23. 5.4L What changed between 98 & 99??
  24. 98 5.4L More power for street and towing
  25. 4.6 to 5.4
  26. the "other" coolant caused misfire?!?!
  27. P0420 (what is it?)
  28. Looking at 04 6.0 CC 4x4
  29. Pcv
  30. code PO300 and a PO307
