- Fuel Problems..Where is the FPDM on 2004 F250 SD 5.4?
- 1998 4.6 fuel Pressure Issues
- hard start,cranks long....
- 98 Expedition w/ 4.6L
- 1997 5.4 loss of rpms
- Spark Plug Boots?
- Flickering Check Engine Light, Loss of Power 1997 F150 5.4L
- Cooling system issue - overpressurization?
- HAS ANYONE REPLACED 5.4 EXHAUST MANIFOLD
- replacing exhaust manifold
- 5.4 Triton Engine Stumbles
- 5.4L eating oil like crazy.. SOLVED
- HELP I need to remove an insert from my 5.4
- '98 5.4 plug blowing questions
- ques. for those runing aftermarket camshafts
- 5.4 fuel issues, crank but no start
- 5.4L sending unit locations - aftermarket
- 06 F250 5.4L
- Common piston slapping or something else?
- 2010 F250 5.4L
- 2006 5.4L P0305 after plug change
- 5.4 ENGINE SWAP 2003 to 1999
- F250 5.4 Rebuild
- engine swap, 04 5.4L into 2001 SD
- Regular or Syn. oils
- 2003 E250 5.4l V8 leaking coolant somewhere
- Engine Temp Gauge Problem
- dislodging updated rocker fingers at 130degrees97 F1504.6l Windsor
- What Is The Life Of The 5.4 Triton
- another 4.6 question
