PDA
View Full Version : Modular V8 (4.6L, 5.4L)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 [169] 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234
  1. 4.6 DOHC Stumble
  2. 5w30 or 10w30
  3. Adjusting Idle After BBK Throttle Body Install
  4. MORE HP! & Better Diff.
  5. 4.6 rod bolts
  6. hesistation on acceleration, 02' 5.4 f150
  7. Timing a 5.4L sohc
  8. Fuel Pump
  9. where to get 4.6 crate motor???
  10. //SIMPLE\\ Best plugs for a 5.4
  11. Remove Fuel Rail To Get To Spark Plug & Ign Coil??
  12. throttle body spacer question
  13. Second time it won't start
  14. 2004 F350 5.4L engine into 2000 F350?
  15. I heads or not PI heads that is the question
  16. Proud new owner But...
  17. oil weight rec. for 5.4L
  18. How long will a 5.4L live?
  19. 4.6 intech to 5.4 parts interchange
  20. Need a progamer for 2 5.4s can it be done?
  21. Oil usage
  22. 4.6 humming noise and rough idle
  23. 2000 5.4 dying at idle
  24. 4.6 intake air temp sensor
  25. Vibration at Idle (revisit)
  26. How long does the 4.6 live?
  27. 4.6L vibration and rumbling at acceleration
  28. How do I increase Gas Milage
  29. milling after heads warped from overheating
  30. 4.6 head swap
