- 2003 F150 4.6 romeo oil pressure
- Truck Won't Start: Theft Light Blinking, Fuel Pump Relay...
- 06 swap in 5.4 out 4.6
- Check engine light and codes
- how to drill and tap plus remove old exhaust stud
- Battery light on....
- 4.6 in a 91 explorer
- Finally Summer...
- vin dosent match engine
- mod motor for 56 f100 project, 4.6 or 5.4?
- 2001 F150 Cylinder 1 misfiring
- 4.6 "Interceptor" Different than Regular 4.6
- 97 4.6 no power/7mpg and coolant issue
- Replacing intake manifold on a 5.4
- New memeber- E150 with 5.4
- 5.4 motor issues in Lincoln Blackwood
- Poor Mileage, all of a sudden, worse than normal!
- 2007 4.6L any input?
- again a COP question
- 5.4 coolant leak at the intake
- Cats . . .
- Wake Up The 5.4l
- Engine shake a little when Idling
- 02 EXPY AWD 5.4L loss of performance above 95 degrees outside temp
- 5.4l timing chain tensioner issue??
- 5.4 heads question
- No PS or brakes on 4.6
- oil in piston chamber
- 2002 F250 5.4 Won't Start after plug repair
- Help with dtc P0304
