PDA
View Full Version : Modular V8 (4.6L, 5.4L)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 [182] 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234
  1. 97 4.6 I need head gasket replace info
  2. 80mm maf
  3. any problems with the 4.6 triton ???
  4. 1997 F150 4.6 won't fire
  5. havent had it a month and now needs alternator!!
  6. 98 ford f150 triton 4.6
  7. mileage in a SD
  8. exhaust y-pipe 5.4L
  9. About to buy a 1998 5.4L; any problems I should be aware of?
  10. 4.6L Rocker Arm
  11. PCM calibration ?
  12. poor start in COLD weather
  13. Cylinder Numbers for 5.4
  14. Missing after new thermostat
  15. I've got an ignorant question
  16. 2001 w/ 5.4L using oil?
  17. 2002 4.6 explorer problem
  18. 2001 SuperCrew 5.4L Misssing
  19. Exhaust leak question
  20. 5.4L Extremely Rough idle, Shutters when accelerating-HELP!
  21. how do you test a 5.4L egr?
  22. What is the oil pressure spec for modular that specs 5w20 oil?
  23. bad iac?
  24. runs rough @ 1000 rpms
  25. 5.4 oil leak at left head gasket?(help)
  26. 5.4 runs rough, won't idle
  27. F150 radiator and engine cooling system
  28. 5.4L whistle?
  29. Run that 5.4...............
  30. Msd-7020??
