- looking for FIPK info.
- 5.4l with bad idle solved
- Resetting '97 F150 Check Engine Light
- cleaning certian engine parts
- which weight oil are you running in the 5.4
- 1999 with 4.6 Idle problem
- 5.4 burning oil on start up
- 5.4 rebuild
- Newbie with exhaust question...
- Still battleing 'start then die' problem.
- 4.6 cracked intake leaking water bigtime
- Cam or heads in a 5.4
- 5.4 vs a triton v8?
- Another 5.4 missing
- Lean Bank 1 code on newly installed motor 4.6
- No idle!!! Help...
- 5.4 locked up with out warning??? Help!!!!
- 4.6L seems sluggish
- Head removal proceedure?
- Installed intake kit, didnt disconnect battery. Do I need to?
- 98 Expedition 5.4L spark plug question.
- 99 F-150 hydraulic lash adjusters
- 5.4 strange rattle
- Oil pressure problems or electrical?
- engine rev
- 4.6 Head Question
- Variable Valve timing advantage?
- Whistle noise
- Whoa!!!
- '98 4.6L still pinging
