Engine missing (5.4)
Old Nov 13, 2008 | 04:13 PM
dantsg's Avatar
dantsg
I have done a complete tune-up including new cops. It runs great at low speeds and under load, but when i'm driving in the 35 to 45 MPH range it is missing. It seems to be right when the truck should shift into high. This is driving me crazy. PLEASE ANY SUGGESTIONS ON WHAT COULD BE WRONG WOULD BE WELCOMED.
Dan
Old Nov 16, 2008 | 04:45 PM
torkum's Avatar
torkum
Did you fill the spark plug boots with dielectric grease?
Old Nov 22, 2008 | 11:38 PM
2003F-350SuperDty5.4's Avatar
Did you gap the plugs to spec? (If it's 3 valve = no adjustment / 2 valve = .052" - .056" which you can double check by looking under your hood at the engine spec sheet) The COP may not be seated correctly which dielectric grease is recommended also at the bottom of the boot, another common mistake is the COP wiring connector is not on all the way, to check that pull on the connector with a little force to see if it pulls off or not) Possibly may have a bad cop or if 3 valve have seen bad plugs straight out of the box, to find it without a datalogger you'll need to generate a code.
Old Nov 23, 2008 | 10:58 AM
dantsg's Avatar
dantsg
2 valve, plugs were gapped and i checked all the connections. It stopped or got better for a week or so after running it with premium fuel and with the overdrive off but started back up yesterday.
Old Nov 23, 2008 | 09:23 PM
Would suspect you have a bad coil on plug. Would be easier to diag if you had a code. Possibly the COP boot has moisture causing a misfire also. Or a COP not properly seated.
Old Nov 26, 2008 | 04:03 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Dan
Make sure your coil retaining bolts are snug.
Our new Ford COP’s, the Sultans of Spark(S.O.S.), have
been designed with both durability and performance in mind.
Please see them at:
http://www.performancedistributors.com/soscoils.htm
Quality was the main feature we stressed when we went to the
drawing board on these coils.
See your FTE special at:
https://www.ford-trucks.com/forums/793806-cop-fte-special.html#post6780133
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Dec 7, 2008 | 09:51 PM
mstiles19's Avatar
mstiles19
sounds like a problem with the COPs i would check all of them over
Old Dec 12, 2008 | 12:52 AM
mudrnnr79's Avatar
mudrnnr79
Did you find it????? Just kidding haha. Just a thought why would it be "running rough at 35 to 45 mph" and not when at idle or something. Good description but I would put my money on a bad U-joint which tends to show itself at 40 mph via vibration.
Old Dec 12, 2008 | 08:20 PM
LxMan1's Avatar
LxMan1
Torque converter lock-up clutch chatter.
Old Dec 13, 2008 | 09:05 PM
dogert4's Avatar
dogert4
I have the 2000 F250 with the 5.4 and i am haveing the same problem. but mine gets so bad i have to turn the motor off then start it back up and it will do fine for awile.
Old Dec 13, 2008 | 10:04 PM
4DTech's Avatar
4DTech
Everytime at 35-45? What kind of vehicle, is this the 98 F-150??? Well if you count the shifts and after you feel the last shift 4th if it does it only after that then I would say you have a torque converter slipping on engagement. Not uncommon. Not cheap either.. A trans flush may cure but may not. Check that, I wouldn't dig into the engine much more. Ignition problems/ misfires would only be present at idle or load. Not at specific speed. 35-45mph is about where the torque converter will engage at light accell...
Old Dec 13, 2008 | 10:40 PM
dantsg's Avatar
dantsg
My problem is happens most times before shifting in to high (OD). I have notice it happening at other times now but still no check engine light....
New Coils/plugs/fuel filter have not solved the problem. i'm starting to wonder if it is in the fuel delivery (injectors / fuel pump)
Old Dec 23, 2008 | 10:12 AM
Stone Mathews's Avatar
Stone Mathews
I had a similar issue with my 5.4L. (Which I did find the solution to.)
It's a long thread, but you will have to read it all to follow my path to repair.
https://www.ford-trucks.com/forums/7...a-bad-cop.html
Stone
dorton
17
Mar 31, 2012 11:23 AM
tc3457
1997 - 2003 F150
Nov 7, 2011 12:07 PM
78 ford f150
Dec 8, 2007 01:44 PM
pappasplace
Apr 10, 2003 08:26 PM
