- 5.4 running like poo
- Water leak on 5.4
- doing cams in a 5.4l?
- 97 4.6L/ Coil packs??
- Question about spark plug repair?
- 5.4 no power @ high RPM
- 98 4.6 no voltage to cpk
- idle problems
- COP/misfire problem!
- Coil Packs, Wire Set & Plugs????
- When did FORD fix the heads on the 5.4L? (Spark Blowout)
- Oil trouble in my 5.4
- what's a cam phaser?
- 97 F250, Light Duty, 5.4 problem
- 98 4.6 no spark
- 97 f150 4x4 4.6 Engine Trouble !!HELP!!
- 98 4.6 missing??
- Lost pcv valve
- I need a diagram or picture of EGR & TB plenum
- 2007 F150 5.4 Upgrades
- 97 4.6L IAC woes
- 1992 crown victoria p72
- Spark plug boots
- dead Battery
- engine swap
- Rod Bearings?
- 5.4L engine question..need help
- 3 Valve head swaps?
- Coil Pack question
- !997 F150 4.6l oil pump
