blown 4.6l motor?
Old Nov 5, 2008 | 03:44 PM
someday's Avatar
someday
blown 4.6l motor?
i bought a 95 tbird monday and it ran fine...it had a tick that went away and an engine code P0102 for the MAF...almost made it home and it died...got it to start at wot but it would knock real bad and it back fired...when it backfired the entire plastic air cleaner blew up into pieces...tried to start it today with a new air cleaner and used maf...same problem and only starts at wot and needs gas to stay alive at 1-2 rpms knocking bad...felt like the starter jammed so i cranked the engine by hand and it is getting hung up...it will almost make a full rev but it jams up and i hear it hit metal on the pside...i dont understand how it could have run so well...first i thought it was electrical but now it feels like a rod or valve...what should be the first thing i should do?
Old Nov 6, 2008 | 04:01 PM
someday's Avatar
someday
well the motor is seized
Old Nov 6, 2008 | 05:43 PM
someday's Avatar
someday
any chance it could be the trans or starter locking it up?
Old Nov 6, 2008 | 08:23 PM
LxMan1's Avatar
LxMan1
Sounds like it possibly hydrolocked. Try pulling all of the plugs out and see if it will turn over and if anti-freeze comes out of any of the cylinders.
Old Nov 6, 2008 | 08:33 PM
someday's Avatar
someday
had all the plugs out
Old Nov 14, 2008 | 11:14 AM
randallrobbins81's Avatar
randallrobbins81
maybe jumped time and now you have valve hitting a piston. or connecting rod came undone and when rotating it by hand till the cranks hits the rod. to check a rod put a screwdriver in each plug hole have some move crank by hand right and left, if you get to one and ot only moves one direction thats the one. id pull valve cover as well and check for a valve maybe dropped
