Heater blend door problem
Old Oct 17, 2007 | 07:57 PM
copyman's Avatar
copyman
Question Heater blend door problem
My 02 explorer had the problem with the heater blend door clicking , now with the control all the way in the red I get no heat, Im assuming the actuator broke that controls the blend door or the hinge on the blend door broke, is there any way to fix this without removing the dashboard?
I seen some post for older explorers blend door fixes but they dont help with 02 and up.
Old Oct 17, 2007 | 08:26 PM
steve(ill)'s Avatar
steve(ill)
read all the way to the bottom of the thread
https://www.ford-trucks.com/forums/5...ed+my+actuator
Old Oct 20, 2007 | 03:55 PM
copyman's Avatar
copyman
I replaced the blend door actuator today, tried the heater and it works.
Took the old actuator apart and found one of the 2 gears inside was missing teeth.
Thanks for the Info steve(ill).
