head light moisture
Old Oct 21, 2007 | 09:13 PM
bigmilt's Avatar
bigmilt
Unhappy head light moisture
alcon,
I have a 97 xlt 4x4 and the passenger side head light has blown several times as well as the fog light. Both have moisture in them. I have replaced the entire fog lite asssembly but still the same thing. I an thinkning about doing the same for the head light plus the are really frosted on the outside of the lens...please help. thank you.
Old Oct 21, 2007 | 09:52 PM
shiloh66's Avatar
shiloh66
I had the same problem with the headlights on my 90 Bronco II. I drilled a small hole(about 1/8 inch) in the lower corner of them. This really helped.As for the exterior of the light, you can try polishing them with a semi coarse rubbing compound used for paint.This will usually help if they arent too bad.
