Engine compression????
Old Mar 8, 2002 | 06:18 PM
garyda's Avatar
garyda
I checked the compression on my 1989 F150 with a 302 engine with 108,000 miles on it. I got 125-130 lbs on each cylinder. Is this good for an engine with this mileage and how does it compare with a newer engine?????????
Thanks
Old Mar 9, 2002 | 11:08 AM
71mustang's Avatar
71mustang
Old Mar 9, 2002 | 05:55 PM
mickelsons's Avatar
mickelsons
it seems like it might be a little low but not too bad, and as long as they are all equal, that is the most important thing to know.
Old Mar 11, 2002 | 05:49 PM
hitecdan's Avatar
hitecdan
Might be a little low, but not bad for the miles. As long as they are all with in 10-15% of each other you should be fine. If there is one that is lower then that then you may have a bad cylinder that needs to be looked into.
