pulled code 300, 303 & 307, still rough
Old Sep 9, 2004 | 09:00 AM
ssn randy's Avatar
ssn randy
1996 5.0,
did plugs, wires, cap and rotor last night after the CEL and above codes. seems to be better but do notice a slight lope to the idle and about 900-950 rpm in drive, usually about 850. think i need to change the IAC? adjust TPS? or is it the ERG? and how to test them to see if its the one.
Thanks for the help,
Randy
Old Sep 9, 2004 | 09:44 AM
pfogle's Avatar
pfogle
Did you reset the computer? What did the codes indicate? Did you look them up on a chart?
Old Sep 9, 2004 | 09:47 AM
ssn randy's Avatar
ssn randy
300 is random misfire and 301-310 i believe is which cylinder but code is same. 301-310 random misfire. cleared code with mictro tuner and restarted truck, no CEL or codes after that. did the tune-up based on the codes
PigFarmer
Dec 9, 2021 04:45 PM
RKraft
Oct 25, 2013 07:44 AM
ki0cn
Mar 29, 2009 03:54 PM
randy-schendel
New Member Introductions
Jul 24, 2006 06:10 AM
Blackstockr
1997 - 2003 F150
Oct 13, 2004 08:19 PM
