I searched some old posts and it pointed me in the right direction but some more input would be great.
Turned on the lights the other night and all i had was head lights. No dash, tail, or parking lights. Checked all fuses and they were all good. Searched on here and found that people had the same problem and it was the headlight switch. I bought a new one from NAPA, put in on and still have the same problem. Looked as if the old switch had gotten hot cause the connector was burnt looking and a little deformed. I bought a new plug with all the wires and still didnt fix it. I put the old switch back on and I can jiggle the **** a little and get everything to work but not at all with the new switch. Somebody mentioned bad wiring somewhere in the dash, but I just don't see it because I can get everything to work with the old switch. If bad wiring was the culprit, seems the switch wouldn't matter. Ive been driving around with the old switch just hanging down while i have it apart and noticed that the switch gets pretty hot. Seems too hot for it to be good.
Sorry for the long post guys. Any ideas??
Thanks
Maybe the new headlight switch is not any good. Usually if you have that problem and messing with the switch gets them to work the switch is bad. If the new switch doesn't work at all, I would say to try another switch.
the org. sw.burnt+deformed? to do that there has to be>[ poor ground /shorting circuit /defective sw.>when they heat up to a certain point there's a "circuit breaker "that cuts out till it cools then come's on again > alot of my ford's had that problem! but in the day time no trouble /there's also a dash relay can cause problems / most likely the sw. but look for resistance"a break" in the elec.circuitry ! and good luck with the 101 of elec faults
dimmer sw. ring any bells too >like putting your foot all most through the floor-boards to get the head lights back on at 60 ml. per is fun too >that corrosive devil works over-timefun on the 101 elec.prob. trail !then go direct line>cut out the crap in between allways works
No I don't have any auxillary lighting anywhere. I thought the same thing about a new switch being bad so I went and got another new switch and same problem. That's two new switches that don't fix the problem.
I suppose the next step is to start checking wires at the connector and following them back and checking resistance.
If anyone has any other suggestions feel free to post them. Thanks guys. And I'll post when I find something.
When this failure occurred to my 1990 F150, the damage extended to the connector on the headlight switch as well. I had to snip it off and replace it with a new connector. It was a PITA, but it solved the problem.
Well I still have the same problem. Ive been searching everywhere for a diagram of what each wire in the switch controls but cant find anything. I have a Haynes manual but the wire colors shown in the book dont match the colors I have in the truck. This is what I have found out so far:
I have 3 hot wires coming into the switch with the switch off. All but one are hot when the switch is on (think the one that isnt hot controls my radio dimmer, which doesnt matter since I have an aftermarket CD player). Checked continuity on the plug and compared it with a 94 model that works great. Connection D2 has a much higher resistance than the 94 (more than double). Connection B2 on the old switch is burnt looking, the wire that connects there is tan/white stripe. Not sure where that runs to though.
Seems it would help if I knew where each wire ran so I could test each wire. Ive read that alot of people have similar problems but noone is posting solutions so I'm feeling lost here...
Color__Terminal____________Description
O/BK___DN________Power to radio LCD display
LG/Y___D1________Power from fuse panel for dome lamp
BK/PK__D2________Switched power to dome lamp
Y/BK___IGN_______Power on when ignition on
BR_____R_________Switched power to marker lamps and tail lamps
R/Y____H_________Switched power to dimmer switch for Hi/Lo headlamps
BK/O___B1________Power from fuse link L for headlamps
T/W___B2_________Power from fuse panel for marker lamps and tail lamps
LB/R___I__________Switched and dimmed power to instrument lamps
Great News! Found that I had no continuity from pin B2 to the fuse block. Found a small section of the wire was melted. Replaced it and installed my previously bought new switch and everything was good to go! Thanks Suburban, for the help.
Thanks guys.
Glad it worked out for you. I was lucky (if you can call it that) in that all of my heat damage was at the switch. Once I replaced the switch and the connector, I was back in business.
There is quite a bit of load going through that switch. Maybe a relay arrangement should have been used?
