Leveling kit? Front end too low...
Old Nov 17, 2008 | 11:27 AM
Brown Falcon's Avatar
Brown Falcon
Question Leveling kit? Front end too low...
The front of my '95 F350 2wd sits too low. I can't find a leveling kit for my year. Anyone have ideas on how to lift the front a little?
Old Nov 17, 2008 | 12:20 PM
PetalumaJoe's Avatar
PetalumaJoe
SuperLift made an add a leaf kit with new centering pins.
I have it and it worked perfect to make the truck level. You might have to get the cams for the spindles or the wheels might look a lil goofy from the radius of the I beam.
Old Nov 17, 2008 | 05:29 PM
Brown Falcon
I've got coils up front... leaf kit won't help
Old Nov 17, 2008 | 07:56 PM
RJG1987's Avatar
RJG1987
go on summit and fat bobs garage, they got bigger coils for you my friend, good luck
Old Mar 18, 2009 | 07:16 AM
tomherrick's Avatar
tomherrick
Something you might want to look into if you haven't already is whether the leveler kit will affect the front end alignment. I bought a used F250 with leaf spring levelers and a mean pull to the right. I took it in for a front end alignment and they couldn't get it even close to spec. I did some research here and was told that it's a common problem with the levelers that were on my truck. I took them off and the same shop was easily able to align the front end. I have no idea whether the coil version might give you the same grief or not, but it might be worth your time to make sure.
Tom Herrick
apensity
6.7L Power Stroke Diesel
May 20, 2013 08:56 AM
apensity
May 19, 2013 12:53 PM
Dusty F.
Sep 25, 2012 06:01 AM
1pfieffer1
Aug 6, 2007 12:03 PM
skirk55
Jul 13, 2006 10:06 PM
