Edge's pressure sensor install?
Old Jan 6, 2012 | 08:36 PM
BKM-WR3's Avatar
BKM-WR3
I have the CS insight along with this sensor Edge Products| Product that I would like to install on my 2006 to monitor my fuel pressure. The problem is that I am not sure where to install it. If someone could give me some help it would be greatly appreciated.
Old Jan 6, 2012 | 08:43 PM
raptor131's Avatar
raptor131
Post #14 https://www.ford-trucks.com/forums/1...tallation.html
Old Jan 6, 2012 | 08:56 PM
BKM-WR3's Avatar
BKM-WR3
Thanks Raptor! I assume I remove something from the fuel pressure test port and screw the pressure fitting in. The hole and thread sizes are the same?
Old Jan 6, 2012 | 09:02 PM
raptor131's Avatar
raptor131
This is made to go there 6.0L Fuel Pressure Adapter
Old Jan 6, 2012 | 09:13 PM
BKM-WR3's Avatar
BKM-WR3
Thank you Raptor!!!
Old Jan 6, 2012 | 11:54 PM
dchamberlain's Avatar
dchamberlain
You don't necessarily need the hose. Many people just use a simple adapter and attach the sensor directly to the fuel pressure test port. You'll need a M12x1.5 (with an o-ring) to 1/8" NPT adapter. Then I used a 1/8" NPT 45 degree elbow, so that the pressure sensor would not run into the upper radiator hose. This has been working for a couple years now.
I got my adapter from DieselManor.com. But any site that sells gauges will have it. You can see the adapter here about 1/3 of the way down the page.
DieselManor - Accessories
Old Jan 7, 2012 | 07:26 AM
BKM-WR3's Avatar
BKM-WR3
Thanks David,
All of this information is very helpful.
horracecox
Alternative Fuels, Hybrids & Mileage
Apr 5, 2018 01:07 PM
martin14sk
Aug 2, 2017 08:42 PM
jedlicka87
Dec 16, 2012 05:22 PM
extrat162
Nov 23, 2010 09:40 PM
brick
6.4L Power Stroke Diesel
Oct 23, 2007 06:50 AM
