low/soft brake pedal
Old Jan 7, 2012 | 07:37 PM
powerstroker100's Avatar
powerstroker100
Hello, my brake pedal is spongy and very low, has no firmness at all, theres no air in the lines I've bled for ****s, has new pads and rotors aswell, slide pins greased
I put on a new powersteering pump and flushed the PS system
could this be a failing master?
or failing hydroboost?
help appreciated thanks fte
Old Jan 7, 2012 | 07:41 PM
PSDlongbox's Avatar
PSDlongbox
sounds like a failing master. push the pedal as far as you can to the floor and hold. See if it slowly sinks to the floor while you are putting constant pressure on it. Don't push as hard as you can, just regular brake pedal pressure. It will feel like it is slowly sinking from under your foot. At least one test for a master.
Old Jan 7, 2012 | 07:57 PM
powerstroker100
if I give moderate pressure at idle in park i can push the pedal to the firewall and here the PS pump whine
Old Jan 7, 2012 | 07:59 PM
PSDlongbox's Avatar
PSDlongbox
Sounds like a master to me. I'm sure somebody else can confirm
Old Jan 7, 2012 | 08:23 PM
powerstroker100
thanks for commenting so fast psd longbox
ill be here
more responses please
Old Jan 8, 2012 | 08:45 AM
69cj's Avatar
69cj
I concur on the master. If it had been the pump you'd have felt it in the steering also.
Old Jan 8, 2012 | 09:54 AM
powerstroker100
Could it really be though, I still have decent stopping power? I think im going to get me self bleeding tool out, put on a new master, and maybe flush 2 quarts out of the hydro system today, just gotta go pick up some ar 15 goodies first haha, stay tuned ill let you guys know how it turns out
Old Dec 3, 2012 | 09:16 PM
DanQ's Avatar
DanQ
What happened? Did you fix your issue? I have a similar issue.
My test of the hydroboost passed. With engine off,, pump brake pedal 4 times until hard, hold with light pressure. Start Engine, pedal will sink and then return.
Trying to figure out if it is the master.
Old Dec 17, 2012 | 04:17 PM
DanQ's Avatar
DanQ
Replaced the master cylinder. Same soft pedal. I can engage ABS with the pedal as it is, but it sure feels poor.
Toll so far, rotors, rebuilt calipers, pads, master cylinder. Lots of bleeding, running, not running, hand vacuum pump, old fashion pedal pumps, No change. At least I got rid of the lot rot on the rotors.
Only theories left. Bleed system again with ABS system enabled via computer. new stainless brake lines, Adjust push rod, (https://www.ford-trucks.com/forums/7...rake-feel.html) Replace hydroboost unit?, Power steering pump?
Old Dec 19, 2012 | 04:32 PM
powerstroker100
replaced power steering pump and had a nice pedal afterwords, this truck is long gone though
Old Dec 19, 2012 | 08:27 PM
jetjockey99's Avatar
jetjockey99
I had the same problem on an 03 F-350 dually after blowing a rear caliper apart. Bleed system several times and never could get a decent pedal, a really problem when pulling a 15000# 5'er with a boat behind it. Found out that if you get air up into the ABS you cannot bleed it out without a scan tool that is capable of opening the ABS solenoids. I had my dealer bleed them for $75.00 and what a difference it made.
Old Dec 20, 2012 | 05:03 PM
DanQ's Avatar
DanQ
powerstroker100 was your steering affected? Mine steers fine, so I'm reluctant to replace the pump.
Old Dec 21, 2012 | 05:20 AM
powerstroker100
my power steering was affected also yes
new pump cleared up my brake and steering problems, truck only had about 100k miles.
However install a filter and flush the system if you replace the pump, mine had trash in the system and ruined the new pump and I got to replace the pump a second time
Old Dec 21, 2012 | 10:35 AM
Mich6.0's Avatar
Mich6.0
I don't see where the power steering pump has anything to do with the braking system, but if it fixed your problem thats good
Old Dec 21, 2012 | 10:43 AM
2006lariat's Avatar
2006lariat
The brakes on these trucks are Hydro Assist. The Steering pump applies pressure to the brakes.
