ECT and EOT temps very low?
Old Jan 7, 2012 | 07:24 AM
rattleNsmoke's Avatar
rattleNsmoke
I realize we are in winter, but my eot and ect's are both within 2-5 deg's of eachother and range when warm from 172-176 degrees. I like the delta spread, but the temps are running cold since the ambient air temp got cold. Last summer, esp when towing they ran normally 190-205 and had a 5-10 deg delta towing. Why does this truck run so cold? Btw, I did a coolant flush and replaced the thermostat last summer.
Mike
Old Jan 7, 2012 | 08:18 AM
npccpartsman's Avatar
npccpartsman
Sounds to me like you have a bad thermostat still. Just because you put in a new one doesn't mean it can't be defective. Temps should be around 190-195 ECT even in winter.
Old Jan 7, 2012 | 08:58 AM
69cj's Avatar
69cj
I was in Williams, Az. last month. Temps. in the teens and my ect was 194. Your t-stat sounds flakey.
Old Jan 7, 2012 | 09:21 AM
rattleNsmoke
I want to throw this idea out to ya'll. What if the VS fan continually ran full out? Would that be pulling the temps down? Is there a sensor that might have gone bad? What should the FSS rpm's be a idle?
Mike
Old Jan 7, 2012 | 09:28 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Hot idle Fan Speed:
KO=0 LI=533 HI=488 OR=0-4000
Old Jan 7, 2012 | 09:37 AM
npccpartsman
Mike
IMHO a fan, even as large as this one is, shouldn't be a real factor at highway speeds. You could have a bad fan sensor but it would probably throw a code.
Old Jan 7, 2012 | 10:57 AM
joe_r_dog's Avatar
joe_r_dog
it the fan was running all the time, u would notice cause its loud, but i dnt think that its the problem. i think its the thermostat.
landscapeguy
6.2L V8
16
Jan 1, 2018 10:21 PM
J ballan
Jun 13, 2017 06:51 PM
351Cleveland C4
34
Jan 9, 2015 05:10 PM
superrangerman2002
6.7L Power Stroke Diesel
Nov 16, 2014 09:46 PM
KIDkiser
Feb 1, 2014 04:03 PM
