OEM head gaskets
Old Oct 1, 2012 | 12:35 PM
DieselVol's Avatar
DieselVol
OEM head gaskets
Getting head studs and am having to get all the parts together. I'm running into the 18mm vs 20mm issue. One seller says the VIN will answer this question. Dude at Tousley Fords says it won't and that we can't order gaskets until after the heads are pulled and measured. Which is true?
Old Oct 1, 2012 | 12:48 PM
tjustice's Avatar
tjustice
I ordered mine by the VIN.....but yours should be 18mm.....
Old Oct 1, 2012 | 01:10 PM
m-chan68's Avatar
m-chan68
3C3Z-6051-CB should be the correct part number for the head gasket set on a 2003 engine.
Old Oct 1, 2012 | 01:13 PM
DieselVol's Avatar
DieselVol
Thanks guys. I'll try Tousley again.
Old Oct 1, 2012 | 06:57 PM
cheezit's Avatar
cheezit
listen to mike. 3c3z is pretty well a give on an 03 engine
Old Oct 1, 2012 | 06:59 PM
DieselVol's Avatar
DieselVol
Got 'em ordered. Ox staggering expense to this little project.
Old Oct 1, 2012 | 07:19 PM
ConvertedFord's Avatar
ConvertedFord
anyone used the victor reinz black diamond gaskets?
Old Oct 1, 2012 | 07:24 PM
DieselVol's Avatar
DieselVol
That is apparently what I got. They are considered OEM, MLS (multilayered steel) and my mechanic was satisfied with them. Got them for $63 each plus tax.
Old Oct 1, 2012 | 08:27 PM
bismic's Avatar
bismic
Victor Reinz head gaskets are not OEM. They are essentially the same as Black Onyx and they have a MUCH higher failure rate than OEM.
Old Oct 1, 2012 | 08:31 PM
DieselVol's Avatar
DieselVol
Well dang. Having a hard time finding the real thing.
Old Oct 1, 2012 | 08:42 PM
UGA33's Avatar
UGA33
The dealer has them. Probably cost you about 300 for both sides. VR are the Black Onyx and more than likely you will be redoing the job if you use them.
Old Oct 1, 2012 | 08:45 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Riffraff Diesel: Ford 6.0L Head Gasket 18mm
Old Oct 1, 2012 | 08:50 PM
DieselVol's Avatar
DieselVol
Originally Posted by texastech_diesel
The Riffraff part number does not match the part number listed above. Should that be of concern?
Old Oct 1, 2012 | 08:58 PM
texastech_diesel
Token Redneck
Clay might just be using a different Ford catalog number for his kits, because both his headgasket PNs are for E-Series vans.
Maybe Mark, Mike or Cheezit can confirm the cross reference, or you can call Clay tomorrow. I don't think there are a ton of 18mm OEM gaskets running around though.
Old Oct 1, 2012 | 09:01 PM
DieselVol's Avatar
DieselVol
Wouldn't even bother checking with those rip-off artists. They asked me $17 plus tax for a degas bottle cap ($6 MORE than MSRP). Got it from Tousley Ford for less than $9, shipping and all. Tousley is out of gaskets and won't have any until the end of the month.
