Fuse Location 2006 Model Year
Old 09-30-2012, 01:04 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Rusty Axlerod has a superb reputationRusty Axlerod has a superb reputationRusty Axlerod has a superb reputationRusty Axlerod has a superb reputationRusty Axlerod has a superb reputationRusty Axlerod has a superb reputationRusty Axlerod has a superb reputationRusty Axlerod has a superb reputationRusty Axlerod has a superb reputationRusty Axlerod has a superb reputationRusty Axlerod has a superb reputation
Well, It comes up in posts sometimes where to look for particular fuses so I thought I'd label up a couple of pictures for future reference. Hope these might be helpful to someone!
A couple of observations also. The pictures are of my truck (in my Sig) and the labels are from my owners manual.
I didn't see anything labeled as "FICM". can someone point out the fuse and relay for that?
https://www.ford-trucks.com/forums/p...ctureid=110887
https://www.ford-trucks.com/forums/p...ctureid=112615
NOTE ON EDIT: the labeling on the under hood picture above has been corrected. Relay #304 is correctly labeled as the one on the corner with 303 to it's right. The photo id in the link below the picture also points to a corrected copy. Sorry for any confusion.
Last edited by Rusty Axlerod; 10-20-2012 at 02:38 PM. Reason: Corrected relay 303 & 304 position
Old 09-30-2012, 02:22 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is online now
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
IDM = FICM so 18 and 304
Josh
Old 09-30-2012, 02:38 PM
mhatlen's Avatar
mhatlen
mhatlen is offline
2006 Bullet-Riddled 6.0
mhatlen is gaining momentum as a positive member of FTE.mhatlen is gaining momentum as a positive member of FTE.
Nice Job Rusty, that makes it simple to locate. Always dread tracking down a fuse location mainly because of the book.
Old 01-12-2015, 04:19 PM
Rusty Axlerod
Another bit of info on this. I should have labeled them but in Ford speak, F1 is the power distrubution box under the hood and F2 is the one under the dash. So if someone says check F2-22, you know right away its in the cab (and 22 is Engine controls). F1-22 would be under the hood (and 22 is ABS coils).
Old 01-12-2015, 10:33 PM
John Irwin
John Irwin is offline
John Irwin has a good reputation on FTE.John Irwin has a good reputation on FTE.John Irwin has a good reputation on FTE.
I might have to print this. GD mice made a nest in my glovebox while the motor was out, and used the owners manual as building material.
Old 03-21-2016, 09:05 PM
oldfordcrap
oldfordcrap is offline
oldfordcrap is starting off with a positive reputation.
Fuse location
This look nothing like my 2006 e350 diesel 6.0?
Old 06-29-2016, 08:27 PM
FordBlueHeart's Avatar
FordBlueHeart
FordBlueHeart is offline
FordBlueHeart has a brilliant futureFordBlueHeart has a brilliant futureFordBlueHeart has a brilliant futureFordBlueHeart has a brilliant futureFordBlueHeart has a brilliant futureFordBlueHeart has a brilliant futureFordBlueHeart has a brilliant futureFordBlueHeart has a brilliant futureFordBlueHeart has a brilliant futureFordBlueHeart has a brilliant futureFordBlueHeart has a brilliant future
Your famous Rusty. 2006 F350 Fuse diagrams - Ford Powerstroke Diesel Forum
Well, your truck is...
Old 06-29-2016, 08:48 PM
Rusty Axlerod
Cool. Always glad to help.
Old 06-29-2016, 09:12 PM
FordBlueHeart
Yes you are. I have this thread saved on my phone for reference. Thank you! I'd rep ya, but my rep gun is jammed.
Old 04-02-2018, 09:58 AM
duallydondon
duallydondon is offline
duallydondon is starting off with a positive reputation.
Thanks
Thanks Rusty ! was able to locate the location of 15 Amp fuse for the horn,,,still wonder why previous owner of 2005 Ford Super Duty would take it out???
Old 04-02-2018, 12:52 PM
Brotherbillstruck
Brotherbillstruck is offline
Brotherbillstruck is gaining momentum as a positive member of FTE.
Probably pulled for another location....or the toddler would not stop blowing it..
1985 Bronco
1978 - 1996 Big Bronco
03-17-2017 08:13 PM
vipersinu2
17
11-30-2016 07:21 AM
Davgt500
6.7L Power Stroke Diesel
31
11-18-2016 09:00 AM
FORDF250HDXLT
23
04-22-2016 09:42 PM
76f350spercamprspeal
97
04-03-2016 10:16 PM
Quick Reply: Fuse Location 2006 Model Year
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
