front axel bearings
Old Sep 30, 2012 | 02:30 PM
buckeyemag53's Avatar
buckeyemag53
front axel bearings
What does it take to repack front axle bearings on a '05 f250 diesel??
Old Sep 30, 2012 | 02:33 PM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
There is no repacking them, they are sealed units that can only be replaced.
Old Sep 30, 2012 | 03:52 PM
run6.0run's Avatar
run6.0run
You might be able to help em last a bit longer by shooting grease into the abs sensor hole. I do it every 100k.
Old Sep 30, 2012 | 05:50 PM
69cj's Avatar
69cj
Is that on 4X2 and 4X4 front ends?
Old Oct 14, 2012 | 12:32 AM
run6.0run's Avatar
run6.0run
Were the 99 up super dutys ever non serviceable. Cause a friend of mine just did his front bearing with a bearing from Oreillys that he got for under $20. I know on ours, it says do not remove, I'm wondering if anyone had ever disassembled an 05 up wheel bearing.
Old Oct 14, 2012 | 10:07 AM
nitrogen's Avatar
nitrogen
grease through the ABS hole, and run em until they become loose
Old Oct 14, 2012 | 12:15 PM
run6.0run's Avatar
run6.0run
I'm gonna b taking mine apart to check it out when they do get loose. Just figured someone has already done it.
Apocalypse
Jun 12, 2017 07:00 PM
buckeyemag53
Oct 1, 2012 07:00 PM
snakedoc
Sep 15, 2012 10:12 PM
JIMRSX
Apr 27, 2010 07:25 AM
3Nails
Apr 30, 2007 03:46 PM
