LPOP help...
Old Jul 12, 2010 | 09:08 PM
  #106
Action4478's Avatar
Action4478
We would like to know how they arrived at this ,with all the the other possibilities that could happen all of a sudden
Old Jul 12, 2010 | 09:16 PM
  #107
F350-6's Avatar
F350-6
My ICP had some oil in it so I changed it. My new one has the same amount of oil in it now. My old one is loaned out to someone with a "real" bad ICP and he's been running it for months.
Skip the ICP part and tow your truck to a shop who will fix it for a reasonable price in a timely manner. We'll help you find a reasonable tow truck company if needed.
Old Jul 12, 2010 | 09:57 PM
  #108
George D.'s Avatar
George D.
well Thats strange they pressur tested the oil system and its the but the first place you can hook a pressure gauge up is the HP oil resivor, at least on the international front cover maybe ford changed it up but in that way very unlikely. The only way to confirm it is the oil pump is to pull it and look at it. But if they did do what they said and you checked the pickup tube the I hope its the pump. But My money is on they have no clue and are guessing its the oil pump because they don't have the tool they were as a ford dealership required to have and are hoping you will take it apart. Yes the ICP shouldn't leak oil but that won't cause the problem you are having.
Old Jul 13, 2010 | 05:58 AM
  #109
MADVAN's Avatar
MADVAN
Originally Posted by MADVAN
Remove your oil filter and check the bypass first.
Bill
Post #9. Year 95 is staked.
Originally Posted by Cuda_jim
Engines built with SN 201681 through 375549 are equipped with the de-aeration valve.
Above could rule out the cover.
Over filling the CC with 2 to 3 qts of oil could rule out a pickup issue.
The term used, it has a weak lpop. What was the cranking pressure of the lpop?
Does it still start if hpop is filled?
I feel for ya. Your at the mercy of boneheads.
.02
B
Old Jul 13, 2010 | 06:16 AM
  #110
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
I'm really sorry you have to go through all of this, Evan.
I bet you're tired of everyone telling you to get the truck out of there to another shop, too.
Things like this are exactly why none of my trucks have ever been back to any shop since I had issues 2 months after the warranty expired on my Black truck. Then again I've been self-employed for a long time and make time to fix my truck when needed.
I understand your predicamant but I'm not sure what else can be done.
Either give them freedom to throw money at it in hopes of fixing it, or pay the towing to another shop (Ooops, I didn't mean to say that again...)
Best of luck.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jul 13, 2010 | 06:28 AM
  #111
MADVAN's Avatar
MADVAN
Jim
I really lean towards the bypass due to the issue started after the inj r&r and was sudden.
This with the thought of the oil was changed at the time of the r&r.
Bill
Old Jul 13, 2010 | 07:01 AM
  #112
Brown Falcon's Avatar
Brown Falcon
.02
B
Tried over filling the CC, still no oil getting to the HPOP.
Best of luck.
Every other shop in the area that I got a quote from was the same price and wouldn't give me a military discount on parts.
Jim
Bill
Oil was changed, could be the bypass as I had to change out my oil cooler o-rings a few months ago.
Old Jul 13, 2010 | 07:13 AM
  #113
Talyn's Avatar
Talyn
I concur with the oil in the ICP.
Mine has oil in it, So i pulled the plug out. cleaned it with electronic cleaner, let it dry, and plugged it back in.
With no oil in the HPOP, they cannot tell if the ICP is bad.
Nor do they probably have a 7.3 tech at the place.
Part of wanting to be a mechanic is the lame problem of testing and retesting of parts with scanners and meters. Most of which us will never have the luxury of having. Like a 130 dollar clamp over amp meter. Just out of our price range.
It applies to fixing anything though, you test and check, review, and check again.
You don't just start swapping in parts, unless you have the parts laying around.
I'm surprised there isn't a military shop that will do the work for you.
Most military vehicles are diesel. Somebody there is going to know.
Old Jul 13, 2010 | 07:22 AM
  #114
Brown Falcon
Yeah, most military vehicles we have are old GM 6.5's in the HMWWV's and the big Osh Kosh 7 tons.
Our Motor Transport guys aren't the sharpest donut in the box either, and our command doesn't allow privately owned vehicles to be worked on in our shops.
Old Jul 13, 2010 | 03:51 PM
  #115
DRRXR's Avatar
DRRXR
Other shop
Whos these guys, Evan?
Home
get the filter pulled and check to see that the spring check is in there. may have fell out during your cooler repair.
Its should be in the hole on the right
Old Jul 13, 2010 | 07:48 PM
  #116
Brown Falcon
I talked to those guys and they quoted me the same price as the dealer did, plus talking to a guy who has lived here in the area for a long time who told me that they send a lot of their powerstroke repairs over to the dealer I have it at now for things they can't fix.
Old Jul 15, 2010 | 02:53 PM
  #117
DRRXR's Avatar
DRRXR
Question
Wow guess thats how deceptive advertising can be.
You have any updates?
Old Jul 15, 2010 | 07:53 PM
  #118
fordpride's Avatar
fordpride
Brownie i have a spare ICP i would be more than happy to send you if you want it PM me your address
Old Jul 16, 2010 | 06:43 AM
  #119
Brown Falcon
Well the special tool they needed was a certain seal driver for the LPOP. They talked to a guy at another shop and he said that he always just uses a rubber mallet to drive the seal in.
So waiting for the LPOP parts to come in. And having them check the bypass up above the oil filter.
I've got the ICP already. Ordered one for $85 shipped. Dealer wanted $180 for it.
Old Jul 21, 2010 | 06:38 AM
  #120
427 fordman's Avatar
427 fordman
Curious Brownie, what are they figuring out??
