LPOP help...
Old Jul 29, 2010 | 11:18 PM
  #166
George D.'s Avatar
George D.
Make sure you tell coastal about the injectors you did right befor and the fact that the dealer probly has no idea where to get oil pressure. I didn't know you tryd filling the HP oil resivor it should have started momentarily off that the resivor is there so you don't have to crank momentarily. But our definitions of tryd to start could be diffrent. Most importantly make sure coastal diesel aproches the problem like it had never gone to the dealer don't want their rettarded ness to affect the guy there. Actualy let them know that some rettard that had no clew what hes doing installed the new oil pump and you may now have 2 reasons your truck won't start. If the dealer saw some presure its not the deairation valve it is most likely injector orings. Ask the dealer for the old parts and inspect them if the pump looks good refuse to pay they didn't fix any thing and as they said oil presure was low then they replaced the pump and it was nonexsistant so they clearly just admitted to miss diagnosing it and improperly installing the part and makeing the problem wores. If you haven't already you need to put their name out here so no one els falls victem to them.
Old Jul 30, 2010 | 06:05 AM
  #167
Brown Falcon's Avatar
Brown Falcon
I will post about the dealer as soon as I get my truck away from them.
Old Jul 30, 2010 | 06:50 AM
  #168
DRRXR's Avatar
DRRXR
Just got through reading everything and catching up. OMG
Evan
Did you ever see if the filter bypass (dirty filter) check valve was still in there?
Old Jul 30, 2010 | 08:13 AM
  #169
Talyn's Avatar
Talyn
Yea, this whole thing, and that check valve could be sitting on top of the oil filter.
Old Jul 30, 2010 | 10:15 AM
  #170
Brown Falcon
Found out that they never even checked the IPR o-rings. Which could bleed off the pressure.
They were checking the oil pressure from the OPS hole and getting nothing.
I've told them to check the bypass several times.
Old Jul 30, 2010 | 04:06 PM
  #171
DRRXR's Avatar
DRRXR
The reason I was mentioning it is that it was not too long ago that the cooler was pulled and serviced.
Good thing your having it towed. Keep us posted.
Old Jul 30, 2010 | 11:07 PM
  #172
Talyn's Avatar
Talyn
I looked up in my filter housing today. I though there is supposed to be a ball bearing in there?
I got nothing. heh.
Old Jul 31, 2010 | 06:10 AM
  #173
DRRXR's Avatar
DRRXR
William
Here is a pic showing one missing on the right side its a sring loaded wafer check/restrictor.
and here its in place 4 parts- spring , sealing coin/flat, washer and retianer clip spring.
Old Jul 31, 2010 | 07:11 AM
  #174
MADVAN's Avatar
MADVAN
The early PSD does not have the clip to hold the installed valve assembly.
Its staked in. Thus the reason it can fall out. Also its the reason for the
change to the clip.
Bill
Old Jul 31, 2010 | 07:16 AM
  #175
DRRXR's Avatar
DRRXR
change to the clip.
Bill
Did not know that Bill. I rep'ed out on you. Wonder what yr the mod came.
Old Jul 31, 2010 | 08:40 AM
  #176
Talyn's Avatar
Talyn
I cannot honestly tell you if anything is missing from mine.
It looks right, I just though there was a ball bearing in there also.
Old Jul 31, 2010 | 09:59 AM
  #177
Cuda_jim's Avatar
Cuda_jim
William, Here's a picture of the stuff inside the by-pass valve. No ball, but a few small parts to get lost. Even the new clipped on style falls out.
Props to kwikkordead....More:
https://www.ford-trucks.com/forums/4...r-housing.html
Old Jul 31, 2010 | 11:07 AM
  #178
Talyn's Avatar
Talyn
I just have a spring.
Does not look like anything else should be in mine, honestly. *shrugs*
unless the filter is up at the top. Ehh, Who knows.
Old Jul 31, 2010 | 12:54 PM
  #179
DRRXR's Avatar
DRRXR
94-97; Updated snap ring retained check valve F81Z-6881-BA
Old Jul 31, 2010 | 02:13 PM
  #180
MADVAN's Avatar
MADVAN
Correct
97 E-series had the update.
