Lets go back to square one and re-read the original problem ...
Note he pulled a couple injectors to fix the miss. Dollar to a dime when he got on it going home passing the vehicle (high oil pressure) one of the top injector o-rings blew out. Now I'm not smart enough to know exactly what would happen but I would think that injector would flood the valve cover starving oil from other injectors and certainly draining the HPOP reservoir.
Good point , It would be easy to verify .. The reason I stayed away from that was the res usually empties slower from an O ring ..Mine are only Wags ...It can happen after a hot run...
I had a link to another site where the problem was pretty much the issue. Unfortunately it got lost. I'll see if I can find it. Basically, as I recall, #2 cylinder top o-ring was destroyed and he could fill the HPOP and the truck would start and run for 3-5 seconds then die and HPOP reservoir was empty.
Brownie, I only mention this because no one else has and hopefully the shop you have it at has not pulled the injectors yet to check it out. If not I would would be asking them to do that before any other major repair possible solution. If nothing else go down and pull them yourself if they will let you. It might be that simple or quite possibly I'm a nut .. wife thinks so.
Before I pulled injectors and suspect an o-ring, I'd take a reading on the HPOil system with a gauge. Then block off the pump eliminating the heads altogether and take another reading right at the pump. If pressure jumps then you know it's in a head. Then connect one head and test again, then the other to find which head has the issue.
If pressure stays low then it's something else and not injectors or inj. o-ring.
It's quite possible that the IPR stuck open and the LPOP can't keep up the res, but not likely if the LPOP is in good shape.
Evan, maybe discuss some of these things with the shop it's at and hopefully they will understand that you do know quite a bit about the 7.3 and just want to make sure they are not throwing your money away.
Tread gently as none of us likes a customer looking over our shoulder.
I'll try to mention those possibilities without being overbearing. I know how it is to be micro-managed and have someone breathing down your neck the whole time (aka military).
They said that the LPOP was still working but not at peak efficiency, but most people on here said that it will gradually wear out over time and usually not fail all at once.
The IPR being stuck open or a bad o-ring sounds like the most likely problem.
You forgot to post the info Travis. I have this if it helps.
Good writeup and pictures. Do you guys have those special tools, or is there another way to pull seal and reinstall. I don't have those tools, and wonder whether you rent them or make something to do the job?
I didn't re read the old thread yet , but ,wondering ,did anyone remove the valve cover and look for oil leaks at the base of an injector ? 3-5 seconds to drain the res ,you might be able to hear it leaking
I've been complaining about my search function not working for a while , glad some one posted the old thread . I dismissed the O rings (based on what I remembered ) from the other thread , thought they were new. Seemingly no leaks after second install. BTW , what was the problem with the injectors that were missing & repaired ?
The armature wasn't seated correctly on those two injectors so they weren't firing.
Re-adjusted, installed and both were firing after that. No noticable oil leaking. Truck ran fine and was shut down and restarted 3 times before dying while passing on the highway.
2X on all that mentioned the IPR stuck open.
If the fuel bowl vent is fouled aerated fuel can also cause issues and lower fuel supply pressure besides the filter and the fuel screen mesh wire. If there is a lot of loose sedimant in the oil the pickup tube can be restricted and the check stuck as well along with the IPR sticking.
Well they still can't find that special tool they need. They've called 3 other dealerships with no luck, waiting to hear from a 4th. They said it's a very expensive tool that is needed to change out the LPOP.
They've had it for 5 days now and no closer to being fixed...
I saw ya pop up and was going to say "Eureka" .. they found the problem.
Geezus Pete....
There's nothing fancy to remove the LPOP. They can get a Harmonic Balancer puller at NAPA, A-Zone or Harbor Freight for that matter. See if that's what they are looking for and buy one yoruself and give to them to use.
Wait, if a reputable shop doesn't even have a friggin pulley puller.... Oh nevermind.
Seriously, find out exactly what special tool they are waiting on. Nothing special is needed...
