LPOP help...
Old Jul 28, 2010 | 11:48 AM
  #136
Brown Falcon's Avatar
Brown Falcon
Ok, bad news.
They installed the new LPOP, still no pressure. I am waiting to here back from the mechanic where he is testing the pressure right now. The service manager made it sound like he was testing it at the oil rails??? That wouldn't give pressure from the LPOP though.
Now they are talking about something being "clogged" and not letting oil get to the LPOP. They want to pull the engine and take the pan off.
If they are checking the pressure at the oil rails and getting nothing that could be injector o-rings causing it to bleed off correct??? I just want to be positive that the injector o-rings could cause this problem. If so I am going to get my truck back and replace the injector o-rings again. I had two injectors out the day that the truck died and they could have gotten damaged.
Old Jul 28, 2010 | 02:40 PM
  #137
Brown Falcon
Ok. They checked the pressure at the sender and are getting no pressure. There is also no oil getting to the LPOP. They tried priming the LPOP and still no pressure...
They said that when they pulled the old LPOP out there was a gooey silicone like substance inside the housing making them think that there is something clogging up the pickup tube.
They are going to try dumping the oil and filling the crankcase with kerosene to see if it will disolve the gunk and break it up.
If that doesn't work they want to pull the engine and check inside the pan.
What was originally a $1,300 repair I don't even want to know what it will be now...
Old Jul 28, 2010 | 02:51 PM
  #138
Action4478's Avatar
Action4478
Didn't you say they had pressure with the old pump, just not as much as they thought it should be ?Now there is none ?
Old Jul 28, 2010 | 05:33 PM
  #139
Brown Falcon
That's what they said. They said that the LPOP isn't getting oil to it, so they suspect a cracked pickup tube or clogged pick-up tube.
They found gunk inside the oil pump housing making them suspect something clogging it.
So they are going to try soaking it in kerosene to see if it will disolve whatever is in there.
Old Jul 28, 2010 | 06:01 PM
  #140
Action4478's Avatar
Action4478
The Pick up tube is submerged in oil , why can't they put air into it to dislodge any gunk?..
If they use a lower pressure , they may be able to hear if it is leaking from the tube ...
Old Jul 28, 2010 | 06:05 PM
  #141
Brown Falcon
I'll suggest that...
I'm just really stressed and frustrated right now. Between the truck and the news that I'm getting medically separated from the Marine Corps within the next few months... So now I"m going to have to move and wont' have a job.
Old Jul 28, 2010 | 06:24 PM
  #142
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Definitely sounds like pre-injector problem.
If they suspect junk or pick-up tube issue, I'd sure like to try blowing air or sticking some wire or something from the LPOP mount into the pick-up tube and see what's there.
I'd worry about trying to disolve what's there. Then what will happen to the junk?
Evan, just so you know I had another customer with some issues after injector install, his truck just up and quit. Tried everything he could think of till he replaced all 8 o-rings again and truck runs great now. If the HPOP res would hold oil but the truck still won't run, I'd say try o-rings, but that doesn't sound like your problem.
Good luck.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jul 28, 2010 | 06:33 PM
  #143
George D.'s Avatar
George D.
That realy sucks man just remember once a Marine always a Marine.
I would defenatly get my truck out of there if they are checking it at the sender well never heard of a oil sender. If its a typo and you meant sensor that would not rule out the deairation valve but since they said it had pressure not a likely cause. injector Orings would cuase it not to start but shouldn't afect the LP oil system. The big thing is no competent mechanic would remove the LP oil pump find junk in it and just replace it.
Old Jul 28, 2010 | 06:44 PM
  #144
George D.'s Avatar
George D.
You know the stuff they say doesn't add up if it had some oil presure it should be able to fill the HP oil resivor and atleast atempt to start. If I had to take a SWAG at it I would say your orings took a dump they were lost trying to diagnose it and found the oil presure was a bit low due to normal wear they replaced the pump forgot to or didn't know to lube the new pump befor they put it in they burt up the new pumpcranking it dry and now are trying to cover there asses. why would it be pumping what ever was in there befor and now be unable to.
Old Jul 28, 2010 | 07:00 PM
  #145
Action4478's Avatar
Action4478
I agree....
Old Jul 28, 2010 | 07:21 PM
  #146
F350-6's Avatar
F350-6
They're just throwing parts at it hoping to get lucky. I'm starting to think they checked oil pressure at the ICP and determined you needed a new LPOP. Tell them to remove the inspection plug off the HPOP reservoir and crank the motor. If the pick up tube is really clogged, then it won't make a mess all over their shop.
If they think you've got a slimy mess floating around in your oil, then have them pull the oil filter and cut it open to see how plugged the filter is. Maybe send an oil sample off to blackstone. If there's enough junk in the oil pan to plug the pick up tube, then your injectors should be shot too. If the pick up tube is cracked, have them over-fill the crank case with oil and jack up the back end. When the oil level in the pan raises above the crack, the truck should start.
If I were you I'd start asking some very specific questions and demanding some very specific answers. Start by determining where they are reading LPO from. If they have been reading HPO numbers, ask them if they blocked off one head at a time to isolate which one has the problem. If your problem is low ICP, it could be injector o-rings.
Old Jul 28, 2010 | 07:26 PM
  #147
Action4478's Avatar
Action4478
I thought that too...
Old Jul 28, 2010 | 07:41 PM
  #148
Skip1970's Avatar
Skip1970
sounds liek you need to go in that shop and kick the grass and watch all the snakes scatter out. semper fi 1371 here, they dont deserve to work on a Marines vehicle.
Old Jul 28, 2010 | 08:11 PM
  #149
MADVAN's Avatar
MADVAN
X2 Chris
Next words will be about a reman dropin.
Just overfill the crankcase with 2 qts of oil.
You can also jack the back of the truck up.
Both above will submerge the pickup for the oil pump.(overfill is a better test)
If the motor starts, the issue is crack at the weld on the pickup bracket
or the flange of the pickup to the pump. The flange also has a gasket.
This dealer dont know chit about a PSD. Nor do they want to open a manual.
The test above is right out of the dealer's troubleshooting/diag manual!
BTW- The only way i have seen pickup tubes clogg is when the motor
has nylon teeth on a cam gear. The PSD does not have this.
.02
Bill
Old Jul 29, 2010 | 06:14 AM
  #150
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
.02
Bill
Even if there was some not-so-correct repairs done to the motor at some point where they used an excess amount of RTV? I'd think it's possible. I've seen some weird repairs on my old, used trucks over the years...
__________________
