LPOP help...
Old Jul 2, 2010 | 12:28 PM
Brown Falcon's Avatar
Brown Falcon
LPOP help...
Still trying to figure out my no-start and no-oil getting to HPOP issue.
Pretty sure my LPOP is shot, but not sure how to change it.
Anyone have a list of tools needed to change it, how long it should take to change, and a write-up or instructions on how to change it out? Pictures would be great...
Ford Dealer quoted me $90 for the LPOP gears and O-ring. They also mentioned something about a cover (front cover maybe?) but said I might not need that.
Old Jul 2, 2010 | 12:42 PM
Action4478's Avatar
Action4478
Some Info ...here ...
Old Jul 2, 2010 | 12:50 PM
Cuda_jim's Avatar
Cuda_jim
Have you considered a cracked pickup tube? It's not common but it does happen.
Test:
]Over fill the crankcase by 2-3 quarts.
Lift the rear of the truck as high as you can get it.
Attempt to start the truck. If it starts the problem is the pickup tube.... not the LPOP.
Old Jul 2, 2010 | 01:45 PM
strokin'_tatsch's Avatar
strokin'_tatsch
I saw that you needed to be signed in to SDD in order to see this so i figured i'd grab it and post it here in case you weren't a member of SDD. I do agree with Jim. I'd check for the cracked pickup tube before messing with the LPOP. If it is the LPOP i think i would get the Melling oil pump from ITP Diesel(now Sinister Diesel...)
Old Jul 2, 2010 | 08:04 PM
Brown Falcon
I'll try it guys.
Old Jul 2, 2010 | 08:20 PM
F350-6's Avatar
F350-6
You forgot to post the info Travis. I have this if it helps.
File Type: pdf
Old Jul 2, 2010 | 08:24 PM
Brown Falcon
Thank you Chris.
Old Jul 2, 2010 | 09:39 PM
oldbird1965's Avatar
oldbird1965
Hey guys, what it be worth his time to maybe change his oil to a straight 50 weight to see if the LPOP will pump it up. If not then it might be the pump. Jim's is a good test also.
Old Jul 3, 2010 | 06:46 AM
MADVAN's Avatar
MADVAN
Remove your oil filter and check the bypass first.
Bill
Old Jul 3, 2010 | 10:41 PM
oldbird1965
Bill, While we stumble thru the dark you provide the light at the end of the tunnel! Falcon, for sure check that!!
Old Jul 3, 2010 | 10:49 PM
George D.'s Avatar
George D.
I hate to say it but every time I saw a T444E with no oil presure it wasn't the pump or the pickup tube, there's a valve in the back of the inner front cover in the oil passage right off the pump that has a bad habbit of falling out. I would still check the pickup tube first then if its good pull the ouil pump and inspect it for knicks, pittting or gaulding. If its good then that fitting probly fell out.
Old Jul 4, 2010 | 07:48 AM
Brown Falcon
Well fellas. I didn't get any good results from testing it, so it's at a shop now. I just don't have the tools or space to take on a project this big.
On another note, Happy Independance Day! Take a minute to remember the reason for this holiday.
To all my fellow Marines out there, Semper Fidelis!
Old Jul 4, 2010 | 08:01 AM
Hussler's Avatar
Hussler
Brownie, you indicated before this problem happened you worked on two injectors for a miss (original thread). Did you have those injectors out? Reason I'm asking is on other sites I've read if the top o-rings are damaged then the HPOP will pump oil out of the reservoir faster than the LPOP can supply it.
Hope the shop finds the problem and it is a simple fix .. $$$ ...
Old Jul 4, 2010 | 12:39 PM
George D.'s Avatar
George D.
OOH-RAH! Happy fourth
Old Jul 4, 2010 | 03:02 PM
Action4478's Avatar
Action4478
De aration valve falling out would certainly cause the sudden issue
