LPOP help...
Old Jul 4, 2010 | 03:57 PM
DRRXR's Avatar
DRRXR
Rick
Is that located in the front of the high pressure oil pump under the cover plate?
Old Jul 4, 2010 | 04:06 PM
George D.'s Avatar
George D.
its screwed in to the rear half of the front cover
Old Jul 4, 2010 | 04:36 PM
DRRXR's Avatar
DRRXR
Yeah thats what I remember now. Seems like they wear out at times and fall out I was trying to help someone locate a replacement part a while back and could not finds one.
Old Jul 4, 2010 | 04:45 PM
George D.'s Avatar
George D.
yeah I always lock tighted them and put them back in I doubt a parts guy would ever be able to find one.
Old Jul 4, 2010 | 05:27 PM
Action4478's Avatar
Action4478
When They fall out ,they are captive in the cover .. I have a pic at work , I'll post it tomorrow
You have to pull the motor to get at it ...
Old Jul 4, 2010 | 06:21 PM
Brown Falcon's Avatar
Brown Falcon
Ok, now you guys are scaring me.
I paid 5 grand for the truck, don't want to spend that much fixing it too...
Old Jul 5, 2010 | 04:11 AM
Cuda_jim's Avatar
Cuda_jim
Here's the picture Rick is talking about, I hope this is NOT your problem....the engine needs to be removed to fix it.
IMAGE001 pictures from trucks photos on webshots
Old Jul 5, 2010 | 04:46 AM
George D.'s Avatar
George D.
I hate thouse stupid things I'm the only one at work thats ever seen it too. Luckilly In a 4700 you can get the oil pan off with out pulling the motor.
Old Jul 5, 2010 | 06:14 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
I don't think all the covers have that, though.
Anyone know what years had them?
I can swear I have a cover with no valve...
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jul 5, 2010 | 07:00 AM
DRRXR's Avatar
DRRXR
I remember that there was a realtively new user on here a month or longer ago that was looking for this part and he could not get the existing to stay in place... Dont know what ever happened on that. I will try searching my post for the thread to see if I can see the out come.
Why is it that you have to pull the motor, room or other?
Old Jul 5, 2010 | 07:12 AM
F350-6's Avatar
F350-6
The oil pick up bolts onto the bottom of the front cover. The oil pan has to be out of the way to unbolt the pick up tube so you can pull the front cover off.
Old Jul 5, 2010 | 07:18 AM
DRRXR's Avatar
DRRXR
Morning Chris
I have read on here where the croaa member was cut out to get the oil pan off and then welded back, is that a option?
Old Jul 5, 2010 | 07:37 AM
  #28
F350-6's Avatar
F350-6
Morning Chris
If you understand enough about the structural properties of the steel, and are able to cut and weld in a manner that does not compromise the integrity of the frame, sure that's an option. Between the bumps on the road and the possibility of a wreck, I think pulling the motor is the easiest option.
If you're completely against pulling the motor, it is possible to just jack the motor up and unbolt and lower the oil pan just enough to get the pick up unbolted. The down side is you've got to then try and scrape the old gasket off the pan and block, wait a week or so for the oil to stop dripping, then pray you get enough RTV on there to make sure there are no leaks during the re-install.
Old Jul 5, 2010 | 07:47 AM
  #29
DRRXR's Avatar
DRRXR
Oh yeah, I am familar with the no resealing the oil pan. Helped a friend with that job. Its like they just dont want to seat right once they are pulled.
Let us know what the shop says Evan.
Old Jul 5, 2010 | 09:05 AM
  #30
Cuda_jim's Avatar
Cuda_jim
Not sure what years but here's the engine serial numbers.
Engines built with SN 201681 through 375549 are equipped with the de-aeration valve.
