Offroad & 4x4
t-case or front end???
Old Feb 16, 2010 | 10:15 AM
  #181
captain p4's Avatar
captain p4
Just don't be under the transfer case when you drop it
Old Feb 16, 2010 | 11:02 AM
  #182
Prozon's Avatar
Prozon
Jee Paul, do you think that much about all of your projects? And another tip for you, don't stand in front of a moving vehicle, that can squish you too.
Oh and Dono, pull the transmission yourself. What are you, a woman?
Old Feb 16, 2010 | 11:51 AM
  #183
alpha/omega's Avatar
alpha/omega
seems like I heard a story about that....
Old Feb 16, 2010 | 12:10 PM
  #184
captain p4's Avatar
captain p4
I don't know, but theres a pretty big hole in the pavement from where it fell. Then I lifted the new one onto the bronco by myself while dubz stared in awe of my strength.
edit: I'm pretty sure he was smoking a cig while that happened too.
Old Feb 16, 2010 | 12:30 PM
  #185
alpha/omega
Doesnt surprise me one bit....
Dubz FTL!
Old Feb 16, 2010 | 11:18 PM
  #186
9.ford.5's Avatar
9.ford.5
im not a woman but i am busy...the wrecker closes at 6 and i dont get off work till 4:30, then a half hour drive to home and then the wreckers... yeah, i really didnt feel like doing that...
the BW1356 probably wouldnt be too bad...its that NP205 i gotta watch out for haha...
man i didnt think id have to cut that much out of my tranny tailhousing to fit that NP-205...wow, no kidden that t-case cracks everything looks like that kills a lot of structural integrity...i should see if i can weld up some braces to that tailhousing to help keep it strong haha
Old Feb 17, 2010 | 08:07 AM
  #187
hav24wheel's Avatar
hav24wheel
Make a separate crossmember for the NP205. The three bolt holes on the left side, and the inspection cover on the other side make a good mounting location. That's what I did on mine when I put in the doubler.
Old Feb 21, 2010 | 02:58 AM
  #188
9.ford.5's Avatar
9.ford.5
i got er dun on wednesday just havent made it on here to let yal know...ill get pics up later...they all crappy cell phone pics though
i have built a mount off that bracket on the d/s of the case to the frame rail...should be fine, for now at least...maybe later ill make one for the p/s too
the NP205 does not ****ing bolt up to the M5DO...i had to hog out the tail housing on the tranny and that input cover on the t-case to make it fit...and i still cracked one of my tailhousing in the process..man i was pissed when that happenend
still gotta get unlazy and finish my shift linkage for the case get my shift boot made and get my front driveshaft in haha...now i r mallcrawler
Old Feb 21, 2010 | 01:42 PM
  #189
Prozon's Avatar
Prozon
And not even a good looking mallcrawler! Wtf!
Old Feb 21, 2010 | 08:07 PM
  #190
quadzjr's Avatar
quadzjr
just another Rockwell looser
had to do the same thing on mine......also had to cut a notch in the tail housing for the shifter rail if i remember correctly
Old Feb 22, 2010 | 12:20 AM
  #191
9.ford.5's Avatar
9.ford.5
but i knew about that part going into it haha...was i pissed when i bolted the t-case to the tranny and has 1/4 inch between the tailhousing and the case...then after modifying everything to fit and some other stuff...about 3 hours of time later, i break the damn tailhousing!!! so i had to start all over again...but the second time was easier i knew how much i had to take off where...boke out the heavy equipment and got er dun LOL
heres those pics...i am missing something....im guessing is a VSS, considering i can see a plastic sleeve on the output shaft with spiral teeth...whatever was in there was strong, the plug i made blew out in a hurry hahahaha....now there oil everywhere but in the case gotta figure that out lol
inserts into the hole below
then my sexeh fab skills...more like 20 min with a drill a torch and an impact gun LOL
this might be a problem...oh well my truck dont flex anyway
and ground hawgs...from the roadkills point of view
Old Feb 22, 2010 | 10:25 AM
  #192
79Ford4x4's Avatar
79Ford4x4
Yeah, that hole is for the spedo gear on the O.E. trucks. Should be a bolt hole beside it. Cut a plate and bolt it on
Old Feb 22, 2010 | 11:08 AM
  #193
Prozon's Avatar
Prozon
Yeah you can see the hole for the bolt. A little piece of metal plate should work out good.
Old Feb 23, 2010 | 12:01 AM
  #194
9.ford.5's Avatar
9.ford.5
yeah i was thinking that...plus side is i wanted to get some decent oil in there anyway...now i have to, probably not much left LOL...oh well chit happens...my breather must be clogged or soemthing, the plug i made didnt even make it home, so there is obviously a fair bit of pressure there
today i got my shifters built for the most part...still need to bend em up a bit so they dont jab into my legs while i r driving...but other than that, no floor pan modification necessary, no extra materials, just used the two shifters and made them work...needs a boot though
all hacked up
all welded up
hey they fit!
Old Feb 23, 2010 | 10:48 AM
  #195
Prozon's Avatar
Prozon
Those welds look like crap. My sixteen year old nephew can weld better than you.
And he's never welded.
Just givin' you a hard time, Looking good though lol. Have you tried it out yet?
