Sponsored by: Real Truck
Gas vs PSD
Old Jan 20, 2011 | 08:13 AM
  #10621
Snowseeker's Avatar
Snowseeker
Diesels can run on french fry oil.
Old Jan 20, 2011 | 08:30 AM
  #10622
dkf's Avatar
dkf
Can the 6.4l and 6.7l do that while still passing emissions testing?
Old Jan 20, 2011 | 08:34 AM
  #10623
Snowseeker's Avatar
Snowseeker
Can a V10 pass up a gas station?
  #10624
scraprat's Avatar
scraprat
Top Answer: 5
While your running on french fry oil, do you deliver burgers and shakes?
Old Jan 20, 2011 | 08:35 AM
  #10625
scraprat's Avatar
scraprat
Top Answer: 5
Sure, until the 400 mile mark.
Old Jan 20, 2011 | 09:34 AM
  #10626
dkf's Avatar
dkf
Thats what I thought. Typical diesel fanboy response.
Old Jan 20, 2011 | 09:53 AM
  #10627
Snowseeker's Avatar
Snowseeker
Can a V10 spit spark plugs?
Old Jan 20, 2011 | 10:43 AM
  #10628
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Gas still sucks and everyone knows it.
Old Jan 20, 2011 | 10:48 AM
  #10629
driximus's Avatar
driximus
Diesel is a better fuel source.
Gasoline: US gallon = 115,000 Btu
Diesel = US gallon = 130,500 Btu
Other sources have #2 up to 140,000 Btu, even bio to vegitable oil has more energy per gallon then regular gasoline.
Old Jan 20, 2011 | 10:51 AM
  #10630
krewat's Avatar
krewat
FTE Leadership Emeritus
scraprat, now see what you've done?
Is that a plus, or a minus? And how much "processing" does it take for them to run the used oil from McD's?
And how cheap is french fry oil that's brand-new in a drum? And can you run it at -20F without a preheater?
I pass them up all the time. Does your HONDA run on gas? My Honda enduro does
Mine doesn't. And most never will.
On the flip side, how many times do you put additives in your tank to stop algae from growing among a whole host of other reasons, drain the water separator, or go to a public place and smell like diesel fuel?
But then, some people get off on offending strangers
Old Jan 20, 2011 | 10:55 AM
  #10631
driximus's Avatar
driximus
I will say yes, Since french fry oil will burn cleaner regardless of what engine it is in.
Old Jan 20, 2011 | 11:10 AM
  #10632
weekendwarriorfsw32
Master of Strokes
Yes.........................
Old Jan 20, 2011 | 11:30 AM
  #10633
driximus's Avatar
driximus
Depends on how you look at it.
Processing is filtering it to get it clean so you invest some money up front like everything else. not sure on exactly because I have not done it but when i was looking into it you could set up a filtering station for about 1000 dollars or you could buy some companies set up for around 3000.
setting up the truck last time i looked ran around 3000 also.
4000-7000 dollar set up, now your running on potentially free fuel. Since most places throw the stuff out anyway they dont care who takes it but you have to get it before they put it into the Oil dumpster outside because then it does belong to someone.
Cons- upfront cost
filtering oil
have to collect oil
still have to run diesel to start and before shut downs.
Pros- Fuel is potentially free.
burns cleaner (now you can tell the hippy in the prius your truck
is cleaner then his Prius.)
low operating cost.
Vegi oil offers better lubrication then #2
short term you spend all the money long term fuel is free. Almost forgot your still required to pay tax on the fuel you use.
EDIT: biggest con of them all I forgot about. On Veggi oil you cannot soot out stupid drivers.
Old Jan 20, 2011 | 12:01 PM
  #10634
scraprat's Avatar
scraprat
Top Answer: 5
Who me?
Old Jan 20, 2011 | 12:25 PM
  #10635
Kajtek1's Avatar
Kajtek1
Never. I was draining water separators in my first years in California and never found any water. Gave up the procedure 20 years ago.
Diesel pumps are more common to have greasy handles, than gasoline ones, but that what rubber gloves are for. Some station have box of gloves attached on the pump.
Than let's talk how many people die, because the gasoline fumes ignited in the garage?
