Sponsored by: Real Truck
Gas vs PSD
Old Jun 17, 2010 | 08:23 PM
  #4981
Jrfish007's Avatar
Jrfish007
Originally Posted by jac08f250
Well I pay 2.72 here for diesel and gas is at 2.49. So the saving is more for me and plus I will be making around 20 mpg here in the next few days. Already got my CAI on and my spartan tuner and my 5 inch exhaust with DPF delete should be here by the weekend. So the saving is coming.
Yeah, I want a CAI too. I hear it adds about 1 mpg for the V10, for $200 it might be worth it. that is true though, those things will save you fuel!
BTW, at your fuel prices, and the PSD getting 20 and V10 getting 15mpg (assuming we both mod as mentioned above), after 100,000 miles, the PSD will save about $3,000. Your savings is $1,500 and mine $240 per year. Where you will really save though is when you sell your truck, because you will recover $5-6k of the cost. So really you 'll break even in less than 2 years. It will take me about 10 years to break even though with the mileage I drive.
Old Jun 17, 2010 | 08:36 PM
  #4982
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by Jrfish007
Humm... I'm not sure what the arguement is here. I already said teh PSD will out pull the V10... I just said the V10 CAN tow just as much as the PSD in SRW form. So if your not towing all the time, why spend $7k to make it up the hill faster? That was my arguement.
Read it again. The V10 can pull the same hill faster.
Old Jun 17, 2010 | 08:49 PM
  #4983
jac08f250's Avatar
jac08f250
Yeah screaming the whole way. While the psd make it up there with ease. I wonder what enigne will have a longer life span.
Old Jun 17, 2010 | 08:56 PM
  #4984
Rush117's Avatar
Rush117
I just pulled 14,000 pounds over Eisenhower Pass the other day. Can your V10 pull the same hill faster with the same load?
Old Jun 17, 2010 | 09:01 PM
  #4985
jac08f250's Avatar
jac08f250
Well of course, cause he will come up with something that will make the v-10 sound like god touched it. You know the v-10 guys need to realize that yes their trucks might be able to tow the same amount but what engine will last longer doing all that towing.
Old Jun 17, 2010 | 09:02 PM
  #4986
Johnny Langton's Avatar
Johnny Langton
Originally Posted by strokin'_tatsch
Man, i don't understand the arguement here.. every V10 i have ever come across whether it was on the street unloaded trying to race me, pulling heavy, or on the drag strip didn't do anything impressive nor has one been able to out run me yet.. So whats supposed to be so cool about the V10's? they don't last long, all their power is in the higher RPM band so taking off from a stop grossing 20k must really suck, and they are slow... pointless engine. V10s should be in cars where high RPM has a purpose, not a truck that weighs 8000 lbs.
What is the torque like on a decently modded V10 anyways? i ask b/c i don't know. decently modded means spending less than around $2200...
My truck @ 21K lbs combined weight,and up a slight incline merging on the highway:
<param name="movie" value="http://www.youtube.com/v/7rBE0-mrOro&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/7rBE0-mrOro&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed>
Tom's 6.4L @ 19,500 combined weight on flat ground:
<param name="movie" value="http://www.youtube.com/v/MwVY3Jhzefo&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/MwVY3Jhzefo&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed>
23 seconds for Tom's 6.4L PSD, and 27 seconds for my 6.8L 3V, Only 4 seconds difference even though I was approx 1500lbs heavier and running up a slight incline.
JL
Old Jun 17, 2010 | 09:04 PM
  #4987
jac08f250's Avatar
jac08f250
You know what I just realize is that the v-10 guys are just as bad as the LS1's guys.
Old Jun 17, 2010 | 09:06 PM
  #4988
jac08f250's Avatar
jac08f250
</PARAM>
</PARAM>
</PARAM><EMBED height=344 type=application/x-shockwave-flash width=425 src=http://www.youtube.com/v/7rBE0-mrOro&hl=en&fs=1 allowfullscreen="true" allowscriptaccess="always"></EMBED></P>
</PARAM>
</PARAM>
</PARAM><EMBED height=385 type=application/x-shockwave-flash width=480 src=http://www.youtube.com/v/MwVY3Jhzefo&hl=en_US&fs=1& allowfullscreen="true" allowscriptaccess="always"></EMBED></P>23 seconds for Tom's 6.4L PSD, and 27 seconds for my 6.8L 3V, Only 4 seconds difference even though I was approx 1500lbs heavier and running up a slight incline.
JL
And what gearing did the psd have? I bet not 4.10's.
Old Jun 17, 2010 | 09:09 PM
  #4989
Johnny Langton
3.73 vs my 4.10's.
My truck has the base gearset for the V10 trucks,and Tom's has the optional 3.73's.
JL
Old Jun 17, 2010 | 09:11 PM
  #4990
jac08f250's Avatar
jac08f250
I would love to see a v-10 tow faster then a psd in the mountains of Co.
Old Jun 17, 2010 | 09:15 PM
  #4991
Johnny Langton
You make it sound like 5200 rpms is "screaming" and excessive. That's only 1700 rpms more than most diesels spin to nowadays. My Tbird has the 4.6L in it-same engine technology and design. I tore down the original engine when I swapped in the built engine at 215K miles. After 215K miles of 6500 rpm shifts and literally thousands of dragstrip passes and daily driving duties, I checked dimensions on every internal dimension of the engine. EVERY SINGLE COMPONENT in the engine was within original factory specs.
JL
Old Jun 17, 2010 | 09:19 PM
  #4992
jac08f250's Avatar
jac08f250
JL
1700 rpms is alot if you tow alot. If you tore down a psd that has towed 15k pounds for 200k miles and did the samething to a v-10 towing that much for 200k miles I bet the v-10 will have alot of wear and tear and damage of the engine. Plus how many more times would you have to fill up compare to the psd if you ran it 1700 rpm higher?
Old Jun 17, 2010 | 09:21 PM
  #4993
jac08f250's Avatar
jac08f250
3.73 vs my 4.10's.
JL
And if you put 4.10's in the psd it would probably gain another 5 seconds or maybe a little more so that would put it 10 seconds or more faster. That's alot since the v-10 makes more power then the psd.
Old Jun 17, 2010 | 09:27 PM
  #4994
bill11012's Avatar
bill11012
The 6.4 can not be had with 4.10s. Its 3.55s or 3.73s. The V10 is 4.10s or 4.30s.
Old Jun 17, 2010 | 09:30 PM
  #4995
bill11012's Avatar
bill11012
The V10 with proper maintance would be in as good of shape or better than the PSD at that mileage.
