Sponsored by: Real Truck
Gas vs PSD
Old Jun 3, 2010 | 09:19 AM
  #4576
CampSpringsJohn's Avatar
CampSpringsJohn
Jet and internal combustion engines are totally different. What my neighbor said was the type of oil used in those engines was so far superior to what the general public has available for their own vehicles. Understand I'm talking 25 years ago. I think he used mobil 1 oil too, but I might be wrong.
Old Jun 3, 2010 | 09:24 AM
  #4577
Jrfish007's Avatar
Jrfish007
The manufacturing process for that oil your talking about is being used in today's high end Euro cars like Porsche's that go 15-20k miles between oil changes on high revving turbo motors. That's why it costs several hundred dollar to change the oil in those too.
Old Jun 3, 2010 | 09:47 AM
  #4578
ChargersFanInCO's Avatar
ChargersFanInCO
The M1A2(SEP) (It's a tank) uses a jet engine, so my jet engine experience is limited...However, it uses an oil filter not much bigger than the one on my truck. The turbine (aka jet) engine only has 2 moving parts which are the high pressure and low pressure compressors. Literally, it's only ONE moving part that needs lubricated, minus the AGB. There is no blow by as the continuous burn portion takes place well after the compressors. If the engine doesn't blow up, (which they always seem to do) in theory, you could go years without changing the oil in it. However, when they get mired up to their turrets (stuck) they usually flood the engine and they have to drain the AGB (Auxiliary Gear Box) and engine (compressor section) which is what gets lubed by the tiny little oil pump on the AGB. As far as the oil used, it uses a regular 15W40 for the engine. The Hydraulic fluid is some of the nastiest stuff on the planet.
Old Jun 3, 2010 | 10:00 AM
  #4579
skoveng's Avatar
skoveng
PSD v. V10.
My F250 CC, LB has a 6.0. My wife's EX has the V10.
The V10 is a rocket out of the hole, the 6.0 a little slower.
However, we have towed our quad trailer to the same mountain location several times with both the PSD and the V10.
With the V10 I watch the speed drop and the gears drop trying to get up the hills. The PSD pulls the same hills with no noticable speed drop and no down shifting.
I love them both; but for me it's the PSD.
Old Jun 3, 2010 | 10:12 AM
  #4580
Jrfish007's Avatar
Jrfish007
Isn't a full synthetic though? I would think the heat might come to be an issue in that application.
Old Jun 3, 2010 | 10:17 AM
  #4581
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by skoveng
PSD v. V10.
The EX never got the 3V, which will out pull the 6.0.
Your comparing Your 6.0 to an older V10 with less power.
Old Jun 3, 2010 | 11:00 AM
  #4582
skoveng's Avatar
skoveng
Maybe true; my 6.0 is a 2003 and the EX is a 2005. The 6.0 has 135K, V10 has 35K.
The 6.0 gets 15 mpg, the EX gets 10 mpg. These are just my experiences.
Still, for me, the PSD; you do have a better chance talking me into a V10 before you could ever talke me into a Chevy!
Old Jun 3, 2010 | 11:25 AM
  #4583
ChargersFanInCO
You know, honestly, I do not know. We ran the same oil in ALL of the vehicles, and it cam from Chevron usually. I don't believe it was a full synthetic. they have heat shields on them everywhere, and you can work on the AGB directly after pulling the FUPP out of the tank. The compressor section really doesn't get THAT hot either. The recuperator does, but it doesn't have any moving parts per se...
Old Jun 3, 2010 | 11:27 AM
  #4584
Johnny Langton's Avatar
Johnny Langton
Just to clarify for those that don't understand it-this is the direct result of forced induction, and is not an indicator of a fuel or engine's superiority.
JL
Old Jun 3, 2010 | 11:31 AM
  #4585
ChargersFanInCO
JL
A Powerstroke is far superior...(ducks flying bottles...)
Old Jun 3, 2010 | 11:38 AM
  #4586
Jrfish007's Avatar
Jrfish007
Interesting, thanks for the info, my practical knowledge of these is really limited.
Old Jun 3, 2010 | 11:45 AM
  #4587
Jrfish007's Avatar
Jrfish007
JL
It's more like a combination of many things, including forced induction, that makes it superior. If it was a matter of just slapping a turbo on, we would have gas powered tractor-trailers running everywhere.
Old Jun 3, 2010 | 11:54 AM
  #4588
Johnny Langton
Don't start tiptoeing around the facts.
Forced induction via a turbocharger is the key reason a turbodiesel is able to pull a load at 2000rpms down the highway and maintain speed without having to downshift.Increasing boost into the intake tract has the exact same result as increasing displacement by that same amount of airflow. Gasoline,Diesel,Propane,Nat Gas,etc,etc...the fuel does not matter-you'll get the same result every time. As boost increases,so does power and torque. A vehicle's ability to maintain speed under load is directly proportional to the amount of boost that the engine receives from the turbocharger, etc. If the turbo isn't the key, then why aren't there any N/A diesel tractor-trailers out there? Why don't the automakers have N/A diesels in their trucks anymore?
I know it's not a simple as slap a turbo on anything and go-the entire fuel and induction system must be designed for that purpose, and/or modified for that use.
JL
  #4589
Rush117's Avatar
Rush117
Originally Posted by Krewat
Comparing jet engines to internal-combustion piston-based engines is an apples-to-oranges thing.
The byproducts of combustion (gases, acids, carbon, etc) wind up in the crankcase of a conventional piston engine.
In jet engines, yes, they get HOT, but the oil is not contaminated over time with the products of combustion.
No matter what you do, an internal combustion engine's oil WILL get contaminated, and no matter what off-the-shelf filter you use, it can't remove all the contaminants.
Absolutely true. The oil in a jet engine is usually checked via sight gauge. It is always the brownish color of clean oil. It never turns black.
JL
I don't care why my truck doesn't downshift at 9,000 feet while going up a hill with a trailer, but it doesn't. I don't care why it gets better fuel economy, but it does. For me, a psd is a package deal. I didn't decide to buy one based on how the engine itself performed. I decided to buy one because of the entire package, turbo and all.
So are you saying that the longer stroke has nothing to do with superior torque of a diesel?
Old Jun 3, 2010 | 11:58 AM
  #4590
Johnny Langton
The 6.0L and 6.4L Powerstrokes have shorter stroke than the 6.8L.
4.13 vs 4.165.
The 7.3L does have a longer stroke, 4.18.
JL
