Sponsored by: Real Truck
Gas vs PSD
Old Jun 6, 2010 | 11:28 AM
  #4681
Sand_Man's Avatar
Sand_Man
For the life of me, I will never understand why some people think an engine must be weak because it makes it's power higher in the rpm range. Look at it this way: a modern Top Fuel dragster needs to rev to about 9,000, do you think THEY are weak? I know, your 7.3 diesel would really put a hurtin' on one if they'd just let you run it...
Old Jun 6, 2010 | 11:37 AM
  #4682
Kajtek1's Avatar
Kajtek1
Very simple - because that how it feels like. Suzuki Hayabusa bike is not making that much less power than our Fords, but to get it from 4-banger it needs to run close to 10,000 rpm.
You want to give it a try and tow 10,000 lb trailer with it?
Old Jun 6, 2010 | 12:29 PM
  #4683
2001400ex's Avatar
2001400ex
Originally Posted by phillips91
The only way to get an accurate comparison is to test both engines on the same dyno on the same day with the same person running the test.
I thought that is what the diesel power mag article was about, PSD and V10 on same dyno... But people still argue that. LOL
Fact is, for pulling, every test we have done has the PSD outpulling the V10. PSD gets more mileage. PSD costs more upfront and costs more to maintain, though is worth more when trading in. You get what you pay for.
Old Jun 6, 2010 | 01:21 PM
  #4684
phillips91's Avatar
phillips91
I didn't look at the diesel power numbers. I was just referring to Bill and the other guy talking about the dyno numbers on the v10 and 6.2. They were ran on two totally different types of dynos, so not really relevant in a comparison of hp numbers.
I'm on the diesel side here, so no need to try to convince me which is the better towing engine. By "better" I don't mean faster though.
Old Jun 6, 2010 | 02:26 PM
  #4685
ChargersFanInCO's Avatar
ChargersFanInCO
Originally Posted by bill11012
Hahaha, you quoted a year old post.
I know....I'm impressed with how long this thread has gone, to be honest.
That said, DIESEL FTW!!!
Old Jun 6, 2010 | 02:28 PM
  #4686
ChargersFanInCO
Originally Posted by jac08f250
I'm not the one who quoted that.
He's confused....They say the mind is the first thing to go...
Old Jun 6, 2010 | 02:34 PM
  #4687
ChargersFanInCO
Originally Posted by Crazy001
But it doesn't. Your 6.4L makes more power throughout it's RPM band than a 5.4L would at similar RPMs. But your 6.4L won't spin to 5,000 RPMs. The 6.4L peaks out at 50 HP less than the 5.4L peaks at.
Are you really going to argue against SAE certified specs?
Why is everyone so hung up on exact numbers between different dynos? This has been discussed over and over on multiple forums. Different dynamometers are going to come up with different figures on identical trucks. This is a fact. Dynos are very useful to compare the DIFFERENCE in power between certain configurations as long as they are measured on the same dyno.
Comparing power or torque figures between two different dynos is pointless.
Torque is defined as the amount of force to make an object rotate. Let's see, the crank in the engine rotates, the xmsn rotates, and the wheels rotate. HP is good when low torque is needed, and if the torque is LOW, to pull up a hill. That said, let's see the rwt figures for a V10. It doesn't have any. It's relying on HP to do that hill, while presenting symptoms of tachycardia.
I just hauled 3yds of fill dirt in the bed of my truck, which overloaded it by far, I know...It was 3000lbs, and I couldn't tell it was back there.
Old Jun 6, 2010 | 02:36 PM
  #4688
ChargersFanInCO
Didn't you see his post times? He was up all night so he was either groggy, tipsy or delirious from sleep deprivation. Being a fan of the Chargers will do that to you...
haha...The CHARGERS!!! will win the SB one of these days...I was up all night. I do side work, and it's amazing how many people wait until the middle of the night to call and say their A/C doesn't work when it's 80 degrees at midnight. Made $2500.00 after parts for the night, so I'm not complaining.
Old Jun 6, 2010 | 02:38 PM
  #4689
bill11012's Avatar
bill11012
Modular motor junkie
A 5.4 could do that without breaking a sweat.
Old Jun 6, 2010 | 02:40 PM
  #4690
ChargersFanInCO
This is where you're ALL confused. Those top fuel dragsters make 1500+ hp, but they are extremely light so they don't need a ton of torque. They do make more torque than HP though.
  #4691
Tom's Avatar
Tom
This is neat, we've probably hit this HP compared to torque argument at least a dozen times in this thread.
There is no torque without horsepower unless it's at 0 RPMs. Torque is the rotational force without respect to RPMs, whereas horsepower is torque at speed.
Low end torque = low end horsepower. Torque is the twisting force, horsepower is what that force means. I think what confuses some people is how peak numbers are normally what is referenced when comparing engines. Turbodiesels really shine with a trailer because of the immense amount of horsepower available all through the usable RPM range. Which isn't to say that the gas engine can't pull just as hard, just that the gas engine has a narrower window in it's RPM range to do it.
The 3V V10 is a great example. From 4-5,000 RPMs it can pull in a comparable manner to our PSDs between 2-3,000 RPMs. The difference is that we're talking about 1/3rd of the PSDs rev range as opposed to 1/5th of the V10s rev range to achieve comparable power output.
Old Jun 6, 2010 | 02:42 PM
  #4692
ChargersFanInCO
They are light, so HP will work in the place of torque. The V10's weigh as much as the Powerstrokes do, and have lower torque ratings, relying on screaming engines and comparable HP numbers to do the same job. That's why they are slow as hell, and their mileage sucks.
Old Jun 6, 2010 | 02:44 PM
  #4693
ChargersFanInCO
Mine didn't warm up...it sucked. I had to drive it around for a bit to get the engine up to temp.
P.S. You're full of crap. My F150 knew it when I had 800lbs in the back of it...with a 5.4
Old Jun 6, 2010 | 02:45 PM
  #4694
ChargersFanInCO
Sorry...I didn't read the entire thread...yet.
Old Jun 6, 2010 | 02:47 PM
  #4695
2001400ex's Avatar
2001400ex
Yeah, was agreeing with ya, and disagreeing with the people who are bringing in all these random HP numbers. LOL
I am curious though why all these show greater HP loss on the V10 at the rear wheel.
