Sponsored by: Real Truck
Gas vs PSD
Old May 22, 2010 | 08:19 PM
  #4456
Crete's Avatar
Crete
Originally Posted by Rush117
Maybe you should try some Loctite.
Old May 22, 2010 | 08:54 PM
  #4457
pappy19's Avatar
pappy19
You 6 leaker dudes are too funny.
Pap
Old May 22, 2010 | 10:04 PM
  #4458
phillips91's Avatar
phillips91
Originally Posted by Sand_Man
How about regular maintenance such as oil, filters and the like? Also, since we are tracking fuel expenses, do we also track miles traveled? I think this is great not just for those who already own their trucks, but for potential buyers as well.
I think it is a good idea to track not only fuel costs but also miles traveled. That way we can come up with a price per mile over the course of the year since we will all be driving different amounts of miles. One guy may drive 50k miles in the year and another might only drive 5k, so total fuel cost isn't fair in that case. I think we should keep track of all expenses, including oil changes, fuel additives(for the diesels), etc.
Old May 23, 2010 | 12:17 AM
  #4459
beaud82's Avatar
beaud82
Originally Posted by Kajtek1
I have my theory why you don't hear about extensive repairs on V10 with over 200k.
Any serious repair at this point usually is putting the truck on junk yard, while diesel owners will spend even $2500 for new injectors -knowing they have lot of life left in the engine.
Still if we find comparable owners of high mileage trucks that would give us real life data.
I have no doubt that fuel savings on diesel at 200k are so enormous, that even $2500 for the injectors will seem very low price to pay.
Let me calculate. 200,000 miles at 15 mpg makes about $40,000 for fuel.
Even if you calculate only 10% savings comparing to gas engine- you have lot of kudos to play with.
actually my dad has a 7.3 with well over 200k. only major repair was the transmission so far. 4x4 with a bullydog chip i believe he stacked it with a 6 position chip and 5 inch exhaust. no other mods. truck runs great. he might have changed a water pump but not while i was at home. well the 1 other mod he has is the oil bypass system and he runs full synthetic oil which we trully believe in in making an engine ast forever be it gas or diesel. he used to get 18 when he first put the bullydog in it but since he put the six position on top of it and the 5 inch exhaust it has gone down to about 14-15 but it runs like a bat out of hell
Old May 23, 2010 | 01:44 AM
  #4460
mountaineer27's Avatar
mountaineer27
im not worried about me. i would buy a v10 before i would buy a 6.0. in fact i was looking at trucks today for a daily driver and keeping the old psd for hauling. loked at an 05 in loved everything about it but the motor. think im gunna get a 05 duramax instead.
Old May 23, 2010 | 06:55 AM
  #4461
Seven-Point-Three's Avatar
Seven-Point-Three
I think at the outset and once amonth the participants will post odometer readings. This will make it an equal playing field for fuel expenses.
Old May 23, 2010 | 07:17 AM
  #4462
Sand_Man's Avatar
Sand_Man
So is this gonna be a separate thread, or are we posting results here?
Old May 23, 2010 | 09:15 AM
  #4463
Seven-Point-Three
I'm thinking seperate thread with each participant posting update onece a month on a set day. Just got to get some more participants.
Old May 23, 2010 | 11:59 AM
  #4464
phillips91's Avatar
phillips91
Originally Posted by pappy19
And you forgot to add another $2000 for a new pump in addition to the new injectors, and if it's a 7.3 with the E4OD or R4100, then add another $3,000-5000 as your "torque-y" 7.3 tranny is about to go south.
Just curious, but where are you getting these prices? An aftermarket, high performance HPOP for a 7.3 costs $589 from Adrenaline(not the $2000 you quote). $5000 is also a bit high for an e4od, since you can buy a new one for less than $1500 or have it rebuilt(stock) for just a couple hundred. A brand new HPOP for my engine costs less than what 3v guys are paying to have their plugs changed at the dealer. I have seen plenty of threads where guys have paid over $600 for a plug change because they were afraid of messing it up by doing it themselves.
http://www.dieselsite.com/index.asp?...ROD&ProdID=894
Here is a link to that "$2000" pump you mention......
Old May 23, 2010 | 03:25 PM
  #4465
Sand_Man's Avatar
Sand_Man
While I can't speak for the pump, the tranny price is shockingly close. A freind of my Dad's had the R4100 replaced in his truck and the price was $3,600. High? You bet, but it is what it is. I have seen trannys on ebay for $1500 with a 3 yr/100k warrantee, but then you get to R & R it yourself, plus pay for shipping, etc.
Old May 23, 2010 | 05:29 PM
  #4466
phillips91's Avatar
phillips91
Labor to remove and install a tranny shouldn't be more than $150-200(at least that is what shops around here charge). If you can buy one online for $1,500 you should be able to have it installed and ready to go for a total of $1,700. I just replaced an e4od less than a year ago, including removal and installation, for $1,500. That was with a 3 year 100k mile warranty too. Did that guy have his replaced at a dealer or have some sort of perfomance rebuild done on it? I know several guys that have paid over $5,000 to rebuild an e4od, but they were nowhere near stock and every last part in them was high dollar.
After my last post(at 1pm) I went and ate lunch and then cleaned my dog lot out. I started working on my cars at 3 pm. It is now 6:30 and I just installed an 8.8" rear end and brake lines in one mustang and put an engine and tranny in my other. That is 3 hours. At $60 an hour that is $180 for everything I just did. If someone charges you more than that to install a tranny, you are getting ripped off.
Old May 23, 2010 | 06:29 PM
  #4467
clintusaf's Avatar
clintusaf
I was quoted 4k for a BTS tranny this month. JW trannys run from 3400 to 5k i believe. Those are the best built in the country.
Old May 23, 2010 | 06:35 PM
  #4468
bucci's Avatar
bucci
Regardless of how fast you are on installation, around here shops go by estimating books. When someone gets an estimate, the shop looks it up in the book to get the time for installation.
So, no matter what shop a person goes to, the time for installation is supposed to be the same and the only thing that differs is the labor rate and miscellaneous charges like if you break a bolt or charging for cleaners by the whole can. If you could do it in less time then that is to your benefit. If it takes you longer then you loose money.
Old May 23, 2010 | 06:53 PM
  #4469
clintusaf's Avatar
clintusaf
Originally Posted by mountaineer27
do we have to include 6.0's? they will make the psd loose for sure
You guys need to start using lose the right way, not loose.
Loose is like the old girlfriend you had from high school.
Lose is like you v10 guys are going to lose this battle.
Old May 23, 2010 | 07:58 PM
  #4470
phillips91's Avatar
phillips91
That's how they are around here too and that's how we used to be at our shop. I just had to replace the e4od in mine about a year ago and I had a shop here do it for me because my garage was full and they only charged $150 to remove the old one and install the new one. When we owned our shop, I think the hourly rate to remove/install a tranny was around 3 hours even though we did it a lot faster.
Read your last sentence though. "Best build in the country." That is always going to cost more than a stock replacement. I can get tremec tko 600 for my mustang for $1,800 or I could have my stock t5 rebuilt for $250, which I did not too long ago. That was with me taking it out and putting it back in, but a full rebuild done by the shop. I'm not saying there aren't $5k e4od/4r100's out there, but they sure as heck aren't stock replacements.
