Between oil changes I spend about $3000 on fuel for my PS.
That is easy saving of over $1000 comparing to V10 in the same truck. I think I can afford to spend $100 extra on oil change. Just put Mobil1 synthetic in it and send old samples to Blackstone. The good workhorse deserves it.
Well crap, you start looking at that kind of fuel savings and I don't know what to say.
The average person will never see the kind of miles I do, so my fuel savings won't apply to everyone. The less they drive, the less they have to worry about those expensive oil changes too though. With my job I put more miles on a vehicle in 6 months than most people will put on theirs in 20 years, so fuel savings are a big deal to me and I will see that $27k in savings in just a couple of years.
Another reason I like the diesel is the durability. I was wearing gassers out every 6 months and I got tired of buying new ones. I would buy a good used one with 70-75k miles on it and in 6 months it would be at 125-150k and worn out. My 5.0 is still going strong at 220k, but all my other high mileage(125k) gassers either limped to the dealer to get traded in or have the engine sitting in my garage waiting to be rebuilt.
Stay out of the turbo, don't floor it to pass people and take your time pulling out from a stop and you can get just as good mpg's towing as you do empty. I have an open trailer, so there isn't much wind resistance either. Once you get a load moving it doesn't take any more power to keep it moving(on the mythbusters mpg's episode) as long as there isn't much added wind resistance.
Edit-My 7.3 is also a bone stock OBS, reb cab, manual, XL with no options. The same as my 5.4, so a fair comparison as far as set ups go. I don't doubt your mpg claims either. There are too many variables in driving style, mods, trailer resistance, terrain, etc, to make a fair comparison. But both of my trucks pull the same trailer, on the same road, with the same driver, so it doesn't get much more fair than that. I make the same offer to anyone though. I will run a tank of gas out pulling what I say I pull and if I get the mileage I say I get, you fill my tank back up and then give me enough money to fill my next tank up for wasting my time.
Well... Josh you are killing the thread.
After several thousands replies, the gaser owners lost the final arguments
I can only confirm your observation that diesel mpg drop while hauling is minimal. With 9000 lb forklift on flatbed my mpg dropped about 5%.
With 5000 lb lowboy trailer with dovetail, my mpg seems to even increase. I tow it slightly slower, so that is a factor, but I am planning to check it farther.
I have done the math, with the number of miles I drive the 7.3 would be a very slight savings in cost. But when you start looking at things breaking as it ages, the V10 is still ahead on repair cost.
The V10 has all the durability of the 7.3. You would not wear one out like your other gassers.
And I can refute that with real world figures.
I have a 2005 Excursion 4WD. 3.73 axle,2V 6.8L,4R100.
Running on the highway solo,it gets 15mpg.
In town it gets 12.5mpg.
Towing my 8000ish lb travel trailer is gets 9-10mpg depending on traveling speed and wind.
My good friend has the IDENTICAL same Excursion in a 2001 7.3L.
SAME gears, SAME trans, SAME 4WD.
Running on the highway emtpy-he gets 17mpg.
In town he gets 14mpg.
Towing a travel trailer the same length,profile and weight as mine-he gets 9-10mpg.
The gassers I have worn out haven't been modulars, but I have seen my share of them wearing out too. I have worn out an 01 Explorer with a 4.0, a 2002 Chevy Tahoe with a 5.3, a 90 Bronco II with a 2.9 and a couple of 2.3 four cylinders in various vehicles in the last couple of years. My full sized Bronco has gone through a couple of trannys, but the engine is still original. I have done a TON of work to it over the years though.
If you compare the common parts that wear out as a vehicle ages, the 7.3 costs the same as a v10. Look up the prices on alternators, starters, water pumps, etc. I have priced them at several different places and my 5.4 and 7.3 are always within about $10 of each other.
Looks like the mentioned samples of PS are bad engines. I was getting 9 mpg with this set towing at 61 mph with couple of mountains peaks to pass.
What you see on the picture is easy 25,000 lb. Won't even comment on aerodynamics.
Heck -slim chances the motorhome driven alone would get that mpg on its gas engine
JL
My figures are real world figures too. You are forgetting one thing though. Your real world figures have two different drivers and two different trailers(similar, but not identical). My real world figures have the same size truck, same gears, same tranny, same 4wd, exact same trailer and the same driver. I am also pulling a trailer that has virtually no wind resistance and you aren't. I welcome you to come along for a ride anytime you want to. If you are ever in this area just look me up.
Edit-As far as gassers losing more mpg's when loaded than a diesel, there is a simple reason for that in my case. On flat ground, you would be correct. With my car hauler I can cruise along in 5th gear with either my 5.4 or my 7.3 on flat ground all day long and barely see a change in mpg's in either of them. The problem is, there isn't much flat ground around here. At 65 mph my 7.3 is right in the middle of its power band and doesn't have to downshift when I hit a hill. My 5.4 has to downshift and turn 4000 rpm to make the same power my 7.3 does at 2500 rpm. That uses a heck of a lot more fuel.
This is driving the same route at the same speed following each other-him leading some, me leading the remainder. Our trailers are the same height, same length, same weight, same number of axles-his is simply laid out differently than mine. For all practial purposes-the same trailer.
JL
The OBS's do typically get better mileage over the super duty's, assuming you have the same setup as far as tranny and differentials. A manual tranny 2 wheel drive will do better than a 4X4 with an automatic too. Drivers habits do need to be taken into account too.
JL
Thats more what I would expect for most people/trucks.
The V10 comes out ahead too.
