Sponsored by: Real Truck
Gas vs PSD
Old May 19, 2010 | 11:21 AM
  #4276
Kajtek1's Avatar
Kajtek1
Originally Posted by Johnny Langton
the increased costs of diesel vehicle maintenance is non-existent.
JL.
It isn't. PS is a bad sample here, with higher oil capacity.
My diesel Mercedes takes less oil than gasoline model I used to drive. Filters are the same.
With diesel at 200k I had to spend $70 for replacing deteriorating fuel orings, while gasoline engine would require 2 spark plugs exchanges in this period. Spark plugs at dealer cost over $400 with labor.
Diesel has a fuel filter on top of the engine that cost $20-40 depends on the model, while gasoline engines have fuel filter under the car, or new models inside the tank. Those with labor will cost you $200-$500.
Old May 19, 2010 | 11:24 AM
  #4277
Johnny Langton's Avatar
Johnny Langton
What's the title of this thread again?
I don't see the word Mercedes in it anywhere.
Your insinuation that gas vehicle owners are simply too cheap or stupid to purchase a diesel is condescending and arrogant.
JL
Old May 19, 2010 | 11:32 AM
  #4278
Kajtek1's Avatar
Kajtek1
Old May 19, 2010 | 12:03 PM
  #4279
pappy19's Avatar
pappy19
My wife had a Mercedes and every time it went into the shop it was $600-800 no matter what was the problem. After 4 years of that, I was a happy camper when I sold it. I'll never buy another one, ever.
Pap
Old May 19, 2010 | 12:13 PM
  #4280
Kajtek1's Avatar
Kajtek1
So now you are blaming the brand for lousy mechanics you had?
My Ford dealer dropped a clamp in my intake -destroying the turbo and giving me only the $3000 quote for a new one.
I still drive the Ford.
Old May 19, 2010 | 12:16 PM
  #4281
pappy19's Avatar
pappy19
2 different cities, same costs. If it wasn't one thing it was another going bad, nothing to do with having bad mechanics, just a lemon.....sorta like the 6 leakers and the sootbagers, I guess.
Old May 19, 2010 | 03:30 PM
  #4282
Lead Head's Avatar
Lead Head
How much would have those injector o-rings cost(or just fuel system o-rings in general?) cost to have replaced at a dealer? An autolite or NGK plug is what, $3-4 a piece? Assuming a V8, you could have replaced the plugs twice yourself while still being cheaper then a set of diesel o-rings. Why are you assuming that a person with a diesel will do all the work themselves, while a person with the gas engine is not capable of changing their own sparkplugs?
Anyways, this isn't about a Mercedes diesel.
Old May 19, 2010 | 03:39 PM
  #4283
Kajtek1's Avatar
Kajtek1
Right. The 286 pages is only comparing 2 engines
FYI the mentioned gas engine has 2 plugs per cylinder where couple of them have 2" clearance for removal. While I did snap-on diesel lines replacement in less than an hour, doing the spark plugs where small error will destroy $150 coil wire is not for everybody. Good plugs cost $10-15
Same applies to fuel filter, where anybody knowing how to hold the wrench will replace the filter on the top of the engine, while not too many will go under gas car and have the fuel spraying into their face.
Wait a minute? Isn't this what we compare on PS and V10?
Old May 19, 2010 | 05:40 PM
  #4284
bill11012's Avatar
bill11012
Modular motor junkie
What the hell are you talking about?
The coil is $40, and a small error will not destroy one.
Good plugs are $3.
I have never had fuel spray me in the face changing mine.
Old May 19, 2010 | 09:36 PM
  #4285
Kajtek1's Avatar
Kajtek1
Bill we diverted from using V10 engines as a boat anchors and are talking diesel v/s gasers in general.
The above was comparison of diesel option and gas option in exactly the same model of Mercedes sedan.
Slightly different story than PS v/s V10 because Mercedes diesel has almost the same weight what gas engine.
PS is pretty outdated engine comparing to V10 and that is why this topic has some sense to start with.
Would you compare cdi engines from last decade to V10, there would be no comparison. Unfortunately pickups with cdi in US still don't exist. At least not in numbers you can see.
Old May 19, 2010 | 09:40 PM
  #4286
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
All 2008+ Ford trucks are CDI
Old May 19, 2010 | 09:43 PM
  #4287
Lead Head's Avatar
Lead Head
Common Rail Direct Injection I assume is what CDI means? The Dodge Cummins has been common rail since '03, and the GM Duramax has been common rail since it came out in 01. The 08+ Ford 6.4 PSD is common rail as well as the new 6.7...
The 7.3/6.0 PSDs are also technically common rail injection. When the 7.3's HEUI injection system debuted in 1994, it was one of the most advanced diesel injection systems around.
Old May 19, 2010 | 09:47 PM
  #4288
Sand_Man's Avatar
Sand_Man
Why does the word "troll" pop into my head whenever I read one of Kajtec's ramblings?
Old May 19, 2010 | 09:49 PM
  #4289
Sand_Man's Avatar
Sand_Man
There you go with those pesky facts again...
Old May 19, 2010 | 09:52 PM
  #4290
clintusaf's Avatar
clintusaf
I have and it sucked. When i was young and dumb(still applies today), I was changing the fuel filter on my 94 ranger in the auto hobby shop in my BDU's on my lunch break. I had never done it before and didnt think to pinch off the lines. I pulled that sucker out and gas shot down my arm, into my armpit!! you talk about burn!! i had to go home and take a shower and soak my armpit.
just thought i'd throw a funny story in all this madness.
