Crewcab Only Thread.
Old Feb 5, 2022 | 07:10 PM
  #3826
Pitcrw6's Avatar
Pitcrw6
Originally Posted by Oz52F1
Hi All,
I was just wondering.....
Has anybody done or seen a front bench seat in a crewcab that folds back flat to make a bed with the back seat???
Nope not at all. Probably because it might be a safety issue...IDK
Old Feb 5, 2022 | 08:53 PM
  #3827
mwoj's Avatar
mwoj
Hi All,
I always thought this would be cool. Plenty of room to sleep in there that way.
Old Feb 6, 2022 | 10:25 PM
  #3828
1KILLERZ's Avatar
1KILLERZ
I second that. Would be awesome for sure.
Old Feb 8, 2022 | 05:27 PM
  #3829
black & blue 78/9's Avatar
black & blue 78/9
Should be no different than cars with bucket seats that lean way back. Although most do not lay on the back seat but almost flat.
Old Feb 8, 2022 | 06:16 PM
  #3830
Mannysouza's Avatar
Mannysouza
Take the lock out off and fab up some bracketry to run two linear actuators you could even recline the bench a little if you wanted
Old Feb 9, 2022 | 10:14 AM
  #3831
DirtyLarry79's Avatar
DirtyLarry79
Look at the way the front seat back is captured in place. There is a sort of eyelet bolted to both sides of the seat that keeps the back of the seat in place. The wiggle in the seat is from the space in the eyelet. On a normal front seat/ our back seat the eye is made into a hook and when you move the latch for the seat back you’re actually unhooking the same spot the eyelet goes around in our front seats. So it might be possible to modify the hook in the opposite direction to lean back instead of forward.
A stop would complicate things. If you have anything higher than the back seat you’ll be crushing it into the seat. Laying all the way back on the front of the back seat bottom would be nice but it pretty much means your rear floorboard will have to be empty and no one in the back seat. Pretty much no matter what noones gonna be able to be in the back if the front seat is reclined.
I’ll try to post pics of the latch today so we can all visualize it. I believe our front seats have the bar connecting the eyelet on each side just like the latches on the back seats.
Old Feb 9, 2022 | 09:03 PM
  #3832
Mannysouza's Avatar
Mannysouza
I just gave away my seats out of my crew cab. Without them and a tape measure it would be impossible to know for sure. But you could slide the seat all the way forward to add a few inches. I remember the eyelet but that is nothing a die grinder couldn’t fix.
Old Feb 10, 2022 | 12:07 PM
  #3833
Firemedic79's Avatar
Firemedic79
So I’m tossing around the idea of going to a full chassis swap and 12 valve. Curious to what my chassis would be worth. Everything has roughly 1,200 miles on the build.
-1974 crew cab short bed chassis it’s been white wheeled and painted with por15
-Rear Dana 60 4:10 gears and new brakes
-Front is a Dana 44 4:10 yukon gears, yukon limited slip diff, yukon chromoly axle shafts
-Brand new Blue top steering box
-Rear has a shackle flip with 2” block and front has super duty 6” lift springs.
Could sell the engine and trans also, but would separate.
-Engine is a 460, Keith black flat top pistons, procomp aluminum heads, scorpion roller rockers, edelbrock aluminum intake and 650 edelbrock carb.
-Transmission is a 4 spead NP435 with new clutch, pressure plate, and flywheel.
-Transfer case is a divorced NP205
Old Feb 10, 2022 | 02:03 PM
  #3834
somethingclever's Avatar
somethingclever
where are you located?
Old Feb 10, 2022 | 02:14 PM
  #3835
maddogjohnson's Avatar
maddogjohnson
SC according to his profile so relatively close to you, as opposed to the west coast
Are you thinking of getting back in the crew cab game?
Old Feb 10, 2022 | 03:25 PM
  #3836
Firemedic79
outside of Charleston S.C.
Old Feb 11, 2022 | 08:17 AM
  #3837
somethingclever
Actually I have a CC right now - however it's too rare for me to use it, unfortunately.
Original 26k mile ex-fire dept truck and marti report shows 1 of 1.
78 Crew 4x4 - I am the third owner.
Ohio Fire dept sold it in 08 with 13k original miles! it was a museum piece at that time.
The second owner actually used it like a truck....it has some battle scars but was never driven in the snow/salt and always under roof.
It's probably the lowest original mile dent crew in the country?
Thanks - wish it was closer or atleast a day trip for me....
Then again if you want a turn-key firemedic type CC - it seems I have the truck for you. LOL
Old Feb 11, 2022 | 11:21 AM
  #3838
Peter Gozintite's Avatar
Peter Gozintite
I have a short bed crew that I always wished was a 4x4.
Not sure what you would want for it. But I would drop my body on that frame and switch over my engine and trans.
Old Feb 11, 2022 | 04:53 PM
  #3839
Firemedic79
Where are you located? I know I’ve got a lot in it, which I don’t expect to get it all back. I need to sit down and figure it out. It was built over about 2 to 3 year process and I went through a divorce in the middle of all that so it was money here and there when I had a little extra. What do you think is a fair price? You would need the divorced transfer case also right? It also has a Bronco II rear tank, not sure what tank yours has, but the side tank won’t work with the divorced transfer case and additional cross member.
Old Feb 11, 2022 | 08:49 PM
  #3840
Peter Gozintite
I'm in Vegas, and the haul wouldnt be the problem. I probably cant afford it in all honesty. Call me a dreamer.
