Crewcab Only Thread.
Old Jan 27, 2018 | 11:57 PM
  #3451
E-Works's Avatar
E-Works
Anyone have a mint center headliner plastic trim piece that goes from side to side in between the 2 headliners and snaps on to the cab?
Old Jan 28, 2018 | 07:11 AM
  #3452
Pitcrw6's Avatar
Pitcrw6
If someone does have one you wouldn't be able to afford it because it would be priced at about 10k...lol. Good luck even trying to find one. Your best bet would be to make one.
Old Jan 28, 2018 | 02:34 PM
  #3453
maddogjohnson's Avatar
maddogjohnson
It is extremely unlikely that you will find a mint headliner divider.
See post #3436 in this thread for the best options I am aware of.
The Dodge van headliner divider piece is an exact replacement. In my case, it was pretty easy to find one of these once I started looking.
Old Jan 28, 2018 | 10:19 PM
  #3454
husky562xp's Avatar
husky562xp
Anyone looking for a complete crew cab??? has the drip rail rust like most, but is otherwise clean. Truck has A.C. and I do have the seats for it also.
Old Jan 28, 2018 | 10:59 PM
  #3455
pinto_351's Avatar
pinto_351
wheres the cab located?
Old Jan 28, 2018 | 11:11 PM
  #3456
husky562xp's Avatar
husky562xp
Northern Wisconsin
Old Jan 28, 2018 | 11:57 PM
  #3457
pinto_351's Avatar
pinto_351
Originally Posted by husky562xp
Northern Wisconsin
Sent you a PM
Old Jan 31, 2018 | 09:53 PM
  #3458
husky562xp's Avatar
husky562xp
Headliner Piece
This piece here in the pics that snaps onto the cab itself?????
Old Feb 6, 2018 | 12:02 AM
  #3459
maddogjohnson
Hey fellow crew cab junkies.
I'm close to putting a new exhaust on my crew cab from the headers back. Headers are Sanderson FF-427. Looking for informed feedback on the pro's and con's of Y to a single pipe, vs duals that are separate all the way back or have an H or X crossover. My application is an automatic, 4wd with plans to add a gearvendors overdrive unit down the road. I'm leaning towards side exit behind each wheel. I'll also have a 19 gallon tank aft of the axle.
Trying to keep my cab quiet, and avoid a drone at cruising speed without sacrificing performance too much so mufflers will not be anything too loud. I'll be putting down GTMat and carpet in cab.
Pics and comments welcome.
Old Feb 6, 2018 | 06:29 PM
  #3460
Pitcrw6's Avatar
Pitcrw6
I had a H pipe with exit on the sides before the tires and loved it. It had a deep throaty sound but nothing annoying.
Old Feb 7, 2018 | 06:54 PM
  #3461
lakequ's Avatar
lakequ
https://www.ebay.com/itm/1973-1979-F...ZY2BXC&vxp=mtr
driver side rear door
Old Feb 8, 2018 | 11:19 AM
  #3462
PACrewCab's Avatar
PACrewCab
Wow.... That's a bit steep for that door.
Old Feb 10, 2018 | 07:39 PM
  #3463
art vandolay's Avatar
art vandolay
Hey Maddog,
'motor trend' (engine masters) did a great video that tested the sound, and HP that resulted from each type of crossover pipe.
Old Feb 10, 2018 | 07:41 PM
  #3464
art vandolay
That ebay door has been for sale for a long time. Before, he was asking $900!
Old Feb 13, 2018 | 01:19 AM
  #3465
maddogjohnson
Good suggestion on the Engine Masters video. I've watched two videos they have relevant to this topic previously and actually watched both of them again last Friday.
I should clarify that my focus is more so on the following:
1- Y from the drivers side to the passenger side into a single pipe along passenger frame rail to a single muffler, then split at a single in, dual out muffler to dual pipes for exit on both driver and passenger side
2- Y from the drivers side to the passenger side with dual pipes along passenger frame rail to a single dual inlet/dual outlet muffler, then split at the muffler to dual pipes for exit on both driver and passenger side
3- Dual pipes that run on both passenger and drivers side to separate mufflers (similar to this crew cab currently for sale on eBay, though I don't like the center inlet / center outlet mufflers mounted vertically.
