Crewcab Only Thread.
Old Oct 29, 2018 | 08:21 PM
  #3541
wevie's Avatar
wevie
Originally Posted by husky562xp
I have a couple cabs available in Wisconsin if someone is looking
are these available still?
Old Oct 29, 2018 | 08:33 PM
  #3542
husky562xp's Avatar
husky562xp
Red cab sold this weekend. Grey cab is still available
Old Oct 29, 2018 | 08:34 PM
  #3543
husky562xp's Avatar
husky562xp
red cab sold this weekend and Gray cab is still available
Old Oct 29, 2018 | 09:38 PM
  #3544
wevie's Avatar
wevie
im not on these boards much. Mind emailing me details?
wevie0037@gmail.com
Old Oct 29, 2018 | 09:51 PM
  #3545
husky562xp's Avatar
husky562xp
wevie0037@gmail.com
email sent
Old Oct 31, 2018 | 06:15 PM
  #3546
Skip1970's Avatar
Skip1970
what kinda cash you get for them? i need to pull mine out of the bushes and start making it look fancy
Old Nov 4, 2018 | 11:48 AM
  #3547
sticks25's Avatar
sticks25
Brake line set for crew cabs?
I have a 75 crew cab long bed which I bought completely disassembled without brake lines. Is there a source for the set? I have come to terms with getting a super cab set and just making my long runs down the frame rails. However I'm secretly hoping there's a crew cab set for sale out there.....
Andy
Old Nov 18, 2018 | 10:53 AM
  #3548
CCrispe's Avatar
CCrispe
1979 F-250 4x4 Crew Total rebuild advice needed
I am new to the thread and am hoping to get a little help. I started what seamed like a normal rebuild on my 1979 ford F250 Crew cab 4x4 short bed. Like most projects it has morphed to this:
1. 24 valve Cummins conversion
2 5 speed Dodge Transmission and Transfer case
3. 2014 F450 axels Yes Dually
4. Front 4 link conversion
5. F450 steering upgrade
6. 42-inch Rubber
7. 8" lift to clear said rubber
I am looking for anyone who has tried any of the above changes to see if they have any advice or can point out any concerns they had.
Old Nov 18, 2018 | 12:57 PM
  #3549
mofoco1's Avatar
mofoco1
So on the above modifications what has actually been done or are all of those already done and what are you considering doing 1st and so on and so on if some have been accomplished . a little more information would probably help the group out. O and pictures for sure. Are you doing the work or ?Sounds sweet.
Old Nov 19, 2018 | 12:35 PM
  #3550
CCrispe's Avatar
CCrispe
I have completely disassembled the truck Sandblasted the frame and body, and have the axles ready to go in. I have 8" Lift springs being made to replace the rear blocks. It looks like I may be able to build a very strong cross member that would include the transmission support and the mount for the 4 link arms. Not sure if that is a good idea in case I need to service the transmission? Not sure if I can mount an F-450 steering box on the 79 frame and replicate the factory setup? With the weight of the Cummins and the 4 link, I am very afraid of the frame bending. I plan on boxing the frame adding support for the Steering box and Panhard bar. As well as completing the cross member alterations and support for the Cummins. Am I missing anything?
Project truck before disassembly
Frame being sand blasted
F-450 Dana 80 axles
Springs will be removed King coil over shocks will be installed need Mounts for 4 link and Panhard bar and a way to adapt the F-250 steering to F-450.
Rear axle in place. custom springs are being built to replace blocks
Old Nov 19, 2018 | 03:58 PM
  #3551
mofoco1's Avatar
mofoco1
Imho I wouldnt mount the motor trans on a single or even the m/t and suspension on it. Make it easy to work on.if you have not dont a 4 link before, there are greaT tutorials online plus calculators that are free. As far as the frame was it a 250/350 to start with?
Old Nov 20, 2018 | 01:46 PM
  #3552
maddogjohnson's Avatar
maddogjohnson
No crew cab set exists out there but it's not too hard to fill the gap with the super cab route or simply custom bending/building your own. I ended up custom building my own.
Old Nov 20, 2018 | 03:12 PM
  #3553
CCrispe's Avatar
CCrispe
I have the brake lines from my Crew cab and am planning to run all braided lines if you want the old ones?
Old Nov 20, 2018 | 05:56 PM
  #3554
mofoco1's Avatar
mofoco1
Just me but why would you not just make your own. Good to learn how to do it and if you want to modify anything you can at the same time. Myself a do SS hardline fir SK long stationary locations and only use SS braided for the caliper hoses and the drop from the prop valve.
Old Nov 20, 2018 | 07:14 PM
  #3555
CCrispe's Avatar
CCrispe
Good point, I was thinking I will need to box the entire frame due to the extra stress. Was thinking of running thin-wall pipe as conduit before I enclose the frame on both sides. My goal is to make it easy to run wiring if i ever add any accessories and was thinking the flexible hose would allow me to fish it trough. That said I could also run the brake line in the frame prior to boxing it in and just leave service openings where the joints are in case i ever had a leak?
