Sponsored by: Real Truck
Power Door Locks FIXED!!!!
Old Sep 1, 2011 | 10:57 PM
  #721
SpringerPop's Avatar
SpringerPop
Originally Posted by 1988FordBroncoII
Thanks Pop...
I know this is the wrong forum, but in a frantic search via Google, this thread came up, and I was hoping one of you had seen something like this before in a similar tiny little inferior truck !
Not inferior at all! They are perfect if used in the right places for the right purposes.
BTW, I could even provide you with a photo of where the unlock relay is on a SuperDuty! But alas, not a B-II. :-((
Sorry I can't be better help to you tonight.
Pop
Old Sep 1, 2011 | 11:10 PM
  #722
1988FordBroncoII's Avatar
1988FordBroncoII
Was just kidding of course !
Thanks again Pop...
Old Sep 1, 2011 | 11:27 PM
  #723
SpringerPop
Thanks again Pop...
Do you have the wiring diagram?
I do, if you need it...
A lot of pink wires there, all with different tracer colors.
Pop
Old Sep 1, 2011 | 11:30 PM
  #724
1988FordBroncoII
Yes, I do... thanks... it's in Chilton.
When I called Ford today, it took the parts guy 45 minutes to try to locate the part. I don't think he found the right part... he said Ford calls it a "breaker." I did find a breaker behind the carpet above the passenger foot well, and when it tripped, my engine stopped. Reset, the engine started right up. But I don't think he actually found the right part when he gave me the number... AND, he said it was NLA...
Old Sep 1, 2011 | 11:37 PM
  #725
SpringerPop
Looks really simple.
Does your diagram look like this:
Pop
Old Sep 1, 2011 | 11:43 PM
  #726
1988FordBroncoII
yep, exactly like that. Of course, with the way the wires run in the Bronco II, that diagram is just like a hangman stick figure lol!
Old Sep 1, 2011 | 11:44 PM
  #727
SpringerPop
Remember also, it could be a bad NC contact in the Lock relay, too, or a bad ground to the pigtail wire on that one, too.
These relays might be standard Bosch SPDT automotive-types, available at any parts store, so I would stay away from your "friendly" Ford dealer for them.
But I think we've hijacked this thread, and should take it to the other forum from here on.
Pop
Old Sep 2, 2011 | 09:16 AM
  #728
Sparky2531's Avatar
Sparky2531
"Door Ajar"
Thanks Pop...I'll give my door locks a shot or two of WD today. I do remember reading about this in the loooooonnnnggg door actuator thread, but by the time I got through it all I was a little wacky.
Sparky
"Those who the gods wish to destroy they first make angry."
Old Sep 2, 2011 | 12:41 PM
  #729
microdevil45's Avatar
microdevil45
Pop
Just a question where in the world do you guys come up with these wiring diagrams?
Old Sep 2, 2011 | 01:19 PM
  #730
EXv10's Avatar
EXv10
books........
Old Sep 2, 2011 | 05:31 PM
  #731
Sparky2531's Avatar
Sparky2531
Thanks Pop, My truck no longer insists that my doors are ajar.
Sparky
Old Sep 23, 2011 | 01:14 PM
  #732
bwguardian's Avatar
bwguardian
This was a great fix. I did the 5 locks in my wifes 2000 Excursion earlier this week. The first one (passenger rear) took a little while but the drivers side rear door only took about 30 minutes. The front passenger took a little longer and the drivers front about an hour...dang padded entry wiring. The back hatch was not all that bad either. While I was on a roll I did dads 2001 F250 extended cab. I noticed his truck had a hole in the door right where the actuator is which made it much easier...20 minutes start to finish! Now I need to figure out how to fix that back large window motor on the Excursion...
Old Sep 23, 2011 | 05:42 PM
  #733
microdevil45
Originally Posted by EXv10
books........
I understand that but what are the names of said books so in can get them?
Old Oct 7, 2011 | 10:02 AM
  #734
F250 SD's Avatar
F250 SD
Door locks finally working again!!!
So glad I found this site. My door locks haven't worked in years. can't believe how such a little thing can make you feel so much happier with your truck!
Old Oct 7, 2011 | 10:15 AM
  #735
EXv10's Avatar
EXv10
Me too , it's a pain to walk around or reach over and manually operate those door lock posts all the time.
